Page 1 of 3
Alloys making noise, any ideas?
Posted: Thu Dec 08, 2005 11:13 pm
by wesley666
Another question lol, just bought some alloys fitted them myself and after few days steering wheel started shaking so took them to garage to be balanced all sorted.
But now i can hear a noise whilst i'm driving it sounds like a rattling of some kind and its coming from the side of passenger side door around wheel area hard to tell exactly as am driving when i hear it
Am i being paranoid and should just turn music back up as all alloys make this noise or is this serious? any suggestions?
Sorry description is a bit vague just cant but it into words lol
Wesley :(
Re: Alloys making noise, any ideas?
Posted: Fri Dec 09, 2005 12:11 am
by luke
having the same problem :) resorted to turning the music up thou because it comes and goes. let me know if you find out whats causing it.
Posted: Fri Dec 09, 2005 12:53 am
by mysteryboy
Same problem here...comes and goes... :?
Music up seems to solve it... but will need looking into aventually...
Posted: Fri Dec 09, 2005 12:09 pm
by Tris
Maybe one of the wheel weights is fouling the brake caliper.
Did they use stick on weights?
Weights
Posted: Fri Dec 09, 2005 2:53 pm
by wesley666
Ah didnt know ther are weights on wheels?
how would i check this then? cheers
Posted: Fri Dec 09, 2005 5:07 pm
by Alex_6n2
Wheel Bearings!
wheel bearings
Posted: Sat Dec 10, 2005 12:08 am
by wesley666
The alloys are brand new like 3 weeks old now, somesone told me it could be my brake drums causing the noise
Just fitted wheels cant be bothered to take them off again lol
Posted: Sat Dec 10, 2005 12:21 am
by david burton
I bet it's not the wheel, something else - but check all bolts etc around the wheel
perhaps something is trapped in your door?
Re: Weights
Posted: Sat Dec 10, 2005 12:40 am
by Tris
wesley666 wrote:Ah didnt know ther are weights on wheels?
If they're alloys the chances are they are stick on weights which look like this
dotted around the inside and outside edges of the wheel. There won't be as many as that ^^ just one or two of the little segments at a time. They're stuck on with adheasive, so look for any marks etc.
Check to see how close the brake caliper comes to the wheel spokes etc, might not be this at all but just check quickly.
Hope this helps, and let us know what the problem is - if you find it! :lol:
brakes
Posted: Sat Dec 10, 2005 12:24 pm
by wesley666
Ahh found the weights yeah just a few no probs there but i looked at my brake disk, the bit the pads touch. Grabbed it and i rocked slightly went to other side where there is no noise and it does not rock.
so me thinks this is the cause of the problem
How do i stop that from rocking i havent touched it so dont know why its loose, any ideas?
Posted: Sat Dec 10, 2005 1:10 pm
by Tris
So the disc isn't held on properly? :?
Try tightening up your wheel bolts.....
Your wheel holds the disc on :shock:
bolts
Posted: Sat Dec 10, 2005 1:12 pm
by wesley666
oh right weird cause got them balanced at garage last week so should be on properly i'll go look c though
Posted: Sat Dec 10, 2005 1:15 pm
by Tris
Well the disc can't fall off because the caliper holds it on, but it sounds to me as if the garage that balanced the wheels has left one of them a bit loose!
Might be an idea to tighten them up before you do any more driving :lol:
Not sure why else the brake disc could be loose :?
tightened
Posted: Sat Dec 10, 2005 1:29 pm
by wesley666
Just tightened them up they were already tight slight turn in one and went round block still heard noise
So unwound window and stuck head and most of body out of window while dirving (ace ventura style) and its def coming from that wheel and yeah sounds like a loose nut but its not.
When i stopped looked at disk again and it does still move back and forwards slightly and also clockwise and anti clockwise like a few cm's even though my nuts are tight suggestions? :?
AHHHHH
Posted: Sat Dec 10, 2005 1:36 pm
by wesley666
This is anoying me now :evil:
