UK-POLOS.NET - THE VW Polo Forum • Major sub problem.
Major sub problem.
Posted: Sat Aug 30, 2003 12:26 pm
by Mk3 Chris
My sub yesterday stopped working for no reason at all.
I've checked all connections everything seems ok but nothing is going to the sub at all... if I take the connections out the sub and put them to another speaker it works ok, so a signal is being sent.
Any ideas?
Posted: Sat Aug 30, 2003 12:42 pm
by dub envy
sounds like you killed your sub.
if other speakers work on the amp, thenit aint the amp...
did the sub 'pop' or start smoking at any time??
Posted: Sat Aug 30, 2003 1:01 pm
by SpikeyG40
don't really no much about subs, but my friend kept blowing fuses! could it be that, sorry probably not that much help knowing me thats the first thing u checked!
Posted: Sat Aug 30, 2003 3:18 pm
by Mk3 Chris
Took it back to the shop, they checked everything and don't have a clue... they went fukkit... pick another. So i have 2 600w subs now :)
So I recommend A1 when buying sound systems!
Posted: Sat Aug 30, 2003 6:40 pm
by Mk3 Chris
One thing... I have on the amp RCH+ RCH- LCH + and LCH - and will be using it for 2 subs only, what should I do to for bass, I know before I didnt wire one sub per channel, it was wired in a funny way like LSUB+ to LCH+ and LSUB- to RCH- or am I in another world?
How should this be wired to get most bass from the amp, my tweets are coming from the head unit.
Posted: Sun Aug 31, 2003 6:36 pm
by KarlM
Most amps are normal label 'sub-out' and will have some form of Bass Boost. if your amp doesnt have this then it isnt really designed to run amps (more a component amp). Your only option is to wire the right sub to the right channel and the left sub to the left channel.
Posted: Sun Aug 31, 2003 10:58 pm
by Mk3 Chris
Oh well... i'll keep it the way it is then.
