Wheel Fittings
Posted: Sat Feb 11, 2006 4:45 pm
by alexb
Hi guys,
First thing being changed on my soon to arrive polo will be the wheels.
Anyone know what the measurements are???
i.e. the stud pattern, PCD, et etc and the tyres ill need
Gonna be getting a 1.4 match BTW and what tyres would i need for 15s???
Alex
Posted: Sat Feb 11, 2006 5:25 pm
by Ollie_R
The stud size and PCD for the polo is 4x100, and I think the offset for wheels is about ET35.
When I had 15" wheels on my polo, I used 195/45/15 yokohama A539 tyres.
Hope this helps.
Posted: Tue Feb 14, 2006 7:48 pm
by alexb
Are we defo sure on this being the fitment for a 1.4 match 2000????
Posted: Tue Feb 14, 2006 8:14 pm
by Ollie_R
I'm speaking from personal experience, from when I had 15" TSW volcano's on my polo, but I'm 100% sure on the PCD. 195/45/15 is if you want to keep the same rolling radius as stock.
If you want more information on tyres and wheels, there's the MK4 FAQ thread in the MK4 forum, which is useful, as the MK4 and 5 are more or less similar to each other.
The MK4 FAQ thread-
http://www.tigerstyle.co.uk/poloforum/v ... php?t=2175
Posted: Tue Feb 14, 2006 9:22 pm
by alexb
Thanks ollie much appreciated.
Sorry for being a (annoying) dumb ass but the et???? what is das???
I have found some rims that are ET25/37 would these fit???
Posted: Tue Feb 14, 2006 10:11 pm
by Ollie_R
ET is the offset of the wheel. A lower ET means that the wheel sticks out more, and a higher ET means the wheel is sits further in the arch.
As stated in the MK4 FAQ, you should aim for an offset between 35 and 43. With ET27, there probably will be a bit of scrubbage, unless you go with a wheel with a width of less than 7J, you may get away with it, if it isn't too low.
ET explained-
http://www.tigerstyle.co.uk/poloforum/v ... php?t=1967
If you have any questions, don't hesitate asking them, as this place seems friendly and everyone here is happy to help.
Posted: Tue Feb 14, 2006 10:55 pm
by Mk2Adam
time to put on my teaching cap...
this type of offset would be your standard alloy e.g ET38...
this type has a negative offset and would be what's known as deep dish...
hope that helped a little bit
Posted: Wed Feb 15, 2006 10:16 am
by jon_poloV
mines the 1.4 match and mine are pcd 4x 100 et 37, 195-45-15 tyers and no rubbing!
lowered 40mm
Jon
