GTI grille on 1.4 Polo
Posted: Tue Feb 14, 2006 10:13 pm
by Weedle
Im looking at getting a GTI grille for my little 1.4 is it any different to the standard grille fitment wise ?
i dont want to buy one and find the fittings are different or its a slightly different size any help will be appreciated as i absolutely hate the look of the standard grille !!
Posted: Tue Feb 14, 2006 10:32 pm
by loud
it'll just clip straight on
Posted: Tue Feb 14, 2006 11:38 pm
by Si_GTi
Yep, unclip the old, clip on hte new. And it'll look a million times better 8)
cheers
Posted: Wed Feb 15, 2006 9:04 am
by Weedle
Cheers for that - i read on another post that the honeycombe is different ??
Will i have to get different bottom grilles aswell ??
Posted: Wed Feb 15, 2006 11:01 am
by Bran
the gti grill is better, but i'd personally go for a badgeless one.
i dont like mine that much
Posted: Wed Feb 15, 2006 12:42 pm
by DanDiesel
the gti grille does look good and it will just clip straight in!! it doesn't look too outta place with the standard lower grills but if u wanted gti lower grills, then u'd have to buy foglights i think coz all gtis have fogs!
(but don't quote me on this)
Posted: Wed Feb 15, 2006 1:25 pm
by inder
The honeycomb gti grille, is well like honeycomb - the standard middle grille is made up of large slats
So you can replace this on its own. The lower grilles can be replaced also if you wished to, to complete the look and have everything matching
The standard lower grilles are made up of square/diamond holes, with cutouts for the foglights, as said above by Dan, all gti's had spotlights - i.e. cannot buy the lower honeycomb side grilles without a hole
Hope helps
This is when I only replaced the centre grille, have since done the lower one's too (my SE spec has foglights, easy to DIY them in if your spec does not have them though, if you wanted to)
Posted: Wed Feb 15, 2006 2:10 pm
by Weedle
Hey cheers for all the tips and info !!
Anyone got any idea of how much the lower grilles with foglights will cost
mines a 1.4 S DOHC engine
dont know if the loom / plug is ready or if i will have the fun task of wiring it in my self - also what to do about the button on the interior ?? does this come with the grilles/lights
any info will be greatly appraciated
Posted: Wed Feb 15, 2006 2:46 pm
by DanDiesel
have a look in the "order parts from vag-parts.com" forum, near the bottom of the main page! i'm sure someone recently put in an order for 6n2 foglights so all the part numbers should be there!
order them from vag parts, coz vw will try and blag that the loom has to be built up etc and they will be more expensive!!
first of all the wiring loom for the front fogs is already there tucked away behind the front grills, and the switch will need to be ordered with the rest of the kit!
there has been a DIY guide to fitting front fogs on the 6n2. this will list all the parts that u will need and there is a step by step guide about how to locate the loom, remove the grills, and then connect it all up! this is the one i followed when i did it and it was spot on!!
http://www.tigerstyle.co.uk/poloforum/v ... 64&start=0
