clunking noise
Posted: Tue Sep 16, 2003 3:21 pm
by boro_kt
my mk 4 keeps making a clunking noise when going slow/in lower gears.it seems to be coming from under the gearbox,or around that area. have had it checked out by the garage but they couldnt find anything,as the noise had stopped.
Posted: Tue Sep 16, 2003 3:33 pm
by Speedlaw
Do you think it's affected by road conditions? I mean, holes, dips, etc.? It could be the stabiliser hitting the car, but this happens on low cars that actually have stabilisers only, i.e. from 75hp onwards, and diesels too IIRC. No known cure, other than modding the stabi or raising the car...
Captain Obvious to the Rescue!
Posted: Tue Sep 16, 2003 4:19 pm
by KarlM
sounds like the problem harry had when he lowered his - the anti roll bar hitting the hub. if the cars lowered try raising it a fraction
Posted: Tue Sep 16, 2003 5:15 pm
by harry
any idea which side it's coming from?? check the geomatry it may be riding uneven if it's lowered, if you take the front tyres of check if any marks in the arches at the bottom of the arch where the anti roll bar is where something might be touching/hitting.
Posted: Tue Sep 16, 2003 10:05 pm
by boro_kt
its not lowered,but we used to live up a very bumpy road. but ill have a check,the noise comes from the middle prob slightly left to the gearbox..hard to explain!
Posted: Thu Sep 18, 2003 1:46 pm
by funkyfatbeatz
I know what you are saying I get that too
when driving on bumpy roads.
Posted: Thu Nov 27, 2003 11:38 am
by msmartinwsx
Hey all.
I have just purchased a used N reg 1.4. 1L polo. (1996 AFAIK)
I get this clunking noise too... I seems like it is coming from the chair as you can feel the vibrations the best there (oooer ;)).
If the car hasnt been lowered - could it be anything else?
M
Posted: Fri Nov 28, 2003 12:38 pm
by Speedlaw
Hey M,
*Welcome*
If the clunking is coming from the chair, a faulty seat base could be the problem. The gliders have plastic caps on them, and they could be either missing or broken. Other than that, check the front side mount of the seat - it's where the handle is to move them back and forth. It is held in place with a small screw + nut, and they could be loose.
Posted: Fri Nov 28, 2003 1:18 pm
by msmartinwsx
Heya
Figured out what it was.....
When the car was MOTed - they put a new back box on - seems they did it wrong and the connection is too long??!?! so the exhaust it knocking???
Im a non car techy - sorry ;)
M
Posted: Fri Nov 28, 2003 3:54 pm
by Speedlaw
Yeah that could very well be the problem, it's common with non-OE boxes, but it can happen if the normal isn't fitted properly.
Glad you know what the problem is.
8)
