fk highsport
Posted: Sun Feb 26, 2006 6:39 pm
by pagz
anyone know why they make a pinging noise and solved it yet??? Getting on my set on a 60mm drop.....mk5 polo
Posted: Tue Mar 07, 2006 11:45 pm
by P20 DUB
thats pretty weird m8. the tyres catching on the coils?
camber correct?
try wheel spacers up front.
jack up the car spin the wheel and see if it still does it.
failing that lower it properly -100 8) , craig
Posted: Mon Mar 20, 2006 8:10 pm
by pagz
will check it out ... cheers
fk highsport
Posted: Wed Mar 29, 2006 5:14 pm
by girlpants999
i had the same problem with mine, i was wondering what it was for ages, i tried every thing, turns out it was the top mounts, and by the sounds of it its sounds the same as mine did, when i pulled my shocks off my bearings had callapst, but that was only becuse i had cut the mounts down a bit in despration, but any way im pritty sure it the top mount make sure you got every thing the right way, i also used my old top mount first, but i worked out how to use them with the ones supplied, so i would recomend pulling them off and checking so see if every thing is the right way.
