UK-POLOS.NET - THE VW Polo Forum • Help adjusting the time...
Posted: Sun Mar 05, 2006 10:04 pm
by danholland
Hi, I've just bought a 2001 Polo but I don't have the user manual.
Could anyone tell me how to adjust the time as there doesn't seem to be any control for it? The only control near it is to reset the odometer. Shouting at it also seems to make very little difference.
Any help would be very gratefully received.
Dan
Posted: Sun Mar 05, 2006 10:12 pm
by pettsy
if you look closely at the rings around the instruments, you will see a small indectations what you can press in using a ballpoint pen or similar that will enable you to change the time.
hope that helps, Pettsy
Posted: Sun Mar 05, 2006 10:21 pm
by ModifiedMadness
Is it only the GTi that has the analogue clock?
I know that there's two buttons either side of that on the rings that you can press.
Posted: Mon Mar 06, 2006 7:40 pm
by paulzpolo
dont know bout gti's but my 2001 match had a digital clock and you can adjust the time by pressing the left hand button for the hour and right hand button for minutes, as pettsy says the outter ring which have allen bolt heads, postioned at about 5 and 7 o clock (hahaha) these are little button which you use to adjust
