Page 1 of 2
CROSSOVER MOD: How to De-Badge
Posted: Fri Sep 26, 2003 8:51 pm
by mole
De-Badge
Ok, so you don't want people knowing you've got a 1.2 under the bonnet
, or just prefer the smooth look.
To remove the rear badges, just follow these simple steps.
Download the PDF file for offline reference and printing.
Also, get the reader if you don't have it already:
side strips
Posted: Tue Nov 18, 2003 5:36 pm
by Paintdeep
Yeah this is a good way to debadge. You can use a piece of cardboard as an alternative to dental floss if you want.
Do you know if removing side strips on a mk4 is done in the same way?
Posted: Tue Nov 18, 2003 6:06 pm
by mole
Only guessing here as I haven't got a mk4 but I'd say they were stuck on in the same way....so you could use the same method. Not sure if it'll reveal holes though as on the mk6. Better off asking in the mk4 forum
Posted: Tue Nov 18, 2003 7:45 pm
by Geezer
yeah-same on mk4 side strips, no holes
b sure 2 heat up the glue first wit hairdryer
Posted: Sat Nov 22, 2003 8:33 pm
by wul3er
Could some1 tell me if the mk5 polo's have holes for the side bump strips.
And would i be able to use this method to remove them.
Posted: Sat Nov 22, 2003 9:56 pm
by Josh_PoloGTi
MK5 (AKA 6N2, AKA 2000-2002)'s do have holes when you remove the rubbing strips.
If your's are not already painted, it would be a good idea to get them done as imho once painted they don't look too bad.
Not like the MK4
Posted: Thu Feb 19, 2004 1:26 pm
by D17NS X
Is it the same for removing the rear badge???? I wanna fit a beetle one its the same colour as the car!!!!
Posted: Fri Feb 20, 2004 4:23 pm
by polopowah
yeah i wanna de-badge the vw off of my polo 6n2 rear, cos its bloody chunky and ugly! can you use the same method as for de-badging numbers and letters from the rear?
-Ben-
Posted: Sat Feb 21, 2004 1:36 pm
by Speedlaw
The 'VW' badge can be removed just as the other badges, but you'll see a big circular dent where it once was.
Posted: Thu Feb 26, 2004 8:20 pm
by wul3er
Its not a good idea to take the centre VW badge off unless you are willing to fill and paint it. I made this mistake.
Posted: Mon Apr 25, 2005 3:21 pm
by xx_loopy_xx
Some more hints......
You could use boiling water if you dont happen to have a hair dryer, but this does take longer and.... I found out that if you do have like bits of the rubber/glue stuff you can use auto glym paint restorer and rub it alot, and the it comes up all shiny and good!! Hope this helps anyone....?
Posted: Mon Apr 25, 2005 4:33 pm
by polopowah
wow a whole year and nearly 3 months and a post gets re-surrected!
gotta be a record
2pac anyone?
yeah cheers for the help, a nice hot sponge helped me no-end, getting the sticky bits off.
-Ben-
Posted: Thu Nov 10, 2005 1:22 pm
by OMEGASUPR3ME
sum lil basts nicked the rear badge on my mk4
so now there is a whole where it should b
it looks pants now, what can i 'fill' it in with?
Posted: Thu Nov 10, 2005 1:29 pm
by dino
You'll need a metal plate welded on the inside of the boot skin, then it will need to be skimmed with filler until smooth, primed and sprayed.
Or just get a new badge and bang it in
Posted: Thu Nov 10, 2005 1:59 pm
by OMEGASUPR3ME
sounds like a bit of a job so might just get a new badge for now
