fool foolish theives!
Posted: Fri Mar 31, 2006 10:12 pm
by tupac2makaveli71
i want to add a alarm indicator light....i have no alarm or even central locking, (mk2 polo 1989) so basically i can get the components, its just that i want to figure out how i can get the light to come on when the car isnt even moving...any help would be appreciated
Posted: Fri Mar 31, 2006 10:38 pm
by Mk2Adam
i pressume you just hook up one of those fake alarm lights to an always live wire...e.g cig lighter or cd player would be easy if you put it in the middle above the heater controls.
btw i wrote a guide in the guides section on how to install central locking in the mk2
costs about £30
Posted: Fri Mar 31, 2006 11:04 pm
by omicron
http://www.maplin.co.uk/module.aspx?Mod ... =31m3&QV=P
The parking light circuit would be the ideal candidate for a feed. I've not got a diagram to hand to tell you how to do it. Otherwise, you could use a changeover relay.
Posted: Thu Apr 06, 2006 2:53 am
by Tahrey1043
An LED bulb, a watch battery holder, a couple short lengths of wire, some solder, oh and a watch battery should do the job, surely? Maybe a small 555 flasher module between LED and battery too, if you want to be smart.
Probable cost about a quid fifty... make your own mounting hole in the dash (the soldering iron might come in useful there too ... or just a suitable size drill bit)
I used to just plug in this cigarette socket air freshener device i had.... because it had a nice bright green LED on the end to show when it was turned on
If it does its job properly, no-ones going to look at it long or hard enough to realise.
Alternatively, if i still had the car, i would have offered you the (at one time, genuine) alarm status LED already fitted to a blanking panel that's uselessly took up a segment of the dash for the past X years... in return for an intact, bulb-less one of course. No connection on it to any power supply or control, but a good bit of wire still attached..... ah well.
Posted: Thu Apr 06, 2006 10:37 pm
by tupac2makaveli71
sorry i am a noob here! lol sorry for being dumb but i am trying my hardest to learn, i understand that the handbrake light should give off a small current when it is pulld up, but does it still give this current when the ignition is off, what i thought of, is making the little switch that triggers the handbreak light a switch for the flasher module!!! so when the handbreak is pulld up, and the two metal peices or whatever are together teh light works, and wire it straight to the battery...assuming i buy the light from maplins..!
Posted: Sat Apr 15, 2006 12:46 am
by k4lps
you can use the switch on the handbrake but you'll have to take a live feed from somewere in the dash you'll need to use a resister aswell 0.27ohm i think
