any body that has replaced a rear badge?
Posted: Fri Apr 21, 2006 11:13 am
by stani540
i am looking to replace my rear badge with a colour coded one how did everyone get the original badge off?
and secondly how did they get the new badge on wat did u use?
thanks in advance
Posted: Fri Apr 21, 2006 11:30 am
by enimadrummer
I just pulled it off a bit (being careful not to press against the bodywork) and then get a standley knife and cut the glue stuff behind it. After a few cuts it should just pull off.
Then i just used some white spirit to get the excess glue off.
The new badge comes with the glue already on it so all you have to do is line it up and stick it on. I did mine the other day...
Sorry, that pics really bad, havnt got round to taking any proper ones...
Posted: Fri Apr 21, 2006 12:24 pm
by Weedle
Or you can try getting a bit of fishing line - heating up the badges with a heat gun or similar and then slowly using the fishing wire like a garotte and peel it behind the badge and voila its off !!
Posted: Fri Apr 21, 2006 3:50 pm
by ModifiedMadness
enimadrummer wrote:The new badge comes with the glue already on it so all you have to do is line it up and stick it on. I did mine the other day...
Thing is, when it's color coded you have to take the sticky pad off, and it pretty much loses it's stick.
He's buying one I did.
