Changing side peters
Posted: Sat May 06, 2006 9:17 pm
by 1litreheater
Alrite guys to fit some new smoked side repeaters i just need to pop the
old ones out with a flat head then disconnect the wires and connect the
new ones !
cheers
Posted: Sat May 06, 2006 9:52 pm
by wils0n86
You just need to jiggle the indicator and it will becoem loose, then click it out, no need for a flathead, and tbh mate i wouldnt want to use one on mine anyway. the wires are connected via a block anyway that plugs into the rear of the indicator. pull the light out, unplug the block, plug in the new one, fit the light again and your done.
Posted: Sat May 06, 2006 11:22 pm
by ModifiedMadness
You can use a flatheaded screwdriver so long as you're careful, that's how I got mine off and my brothers on his Golf and didn't mark it at all.
Like I say just do it carefully, and make sure it's a thin screwdriver.
Posted: Sun May 07, 2006 12:55 pm
by 1litreheater
cheers lads !
