40mm lower :)
Posted: Wed May 10, 2006 3:49 pm
by danny_boy
ive just had my car lowered 40mm yesterday but looking round the car 2day ive found that the rear drivers side is about 2cm lower than the pasenger side
why is this!!!
the passenger side doesnt look like its been lowered at all
please help
Posted: Wed May 10, 2006 4:06 pm
by olop_chris
hmm sounds abit strange, either somethings wrong or the suspension just needs time to settle in
Posted: Wed May 10, 2006 7:08 pm
by DanDiesel
CymruPolo wrote:Were you parked on even/level ground when looking?
was just thinking that??
Posted: Thu May 11, 2006 7:45 pm
by titch
russ swift had the same problem in his mini not that long ago, he couldnt work out why the passenger side was higher than the drivers side
Posted: Thu May 11, 2006 9:38 pm
by mysteryboy
I had a similar problem. My front left was over 1cm higher... now its gonne down a little but is still a little higher...
Posted: Mon Jun 12, 2006 7:49 pm
by kipper
i know how u feel, mine does it to. at first when i lowered it i realised the springs wernt in the correct place but they sorted themselves out then, even now if i look at it, it sometimes looks like one side is higher then the other. might have something to do with weight siptribution in the engine or something. personally i wouldnt worry about it. might be the ground or springs not in place properly. it might sort itself out........... if not then.............. dunno!!!
Posted: Wed Jun 14, 2006 6:15 pm
by polo power
are you sure the spacers and shims are the right way up? this could cause that to happen, another one is that there is a little clip halfway down your damper, if you are missing that this could also affect it. hope this helps.
