ok, anybody ever tried to...?
Posted: Fri Jun 09, 2006 1:26 pm
by chris_lofty
...put a 1.8 8v golf GTi lump into a mk.2 squareback?
basically ive bin given an 8v GTi engine, gearbox, driveshafts and even brakes (the whole lot) for nothing and im wondering if its worth having a crack at lobbing it into my baby polo or getting rid of it?
i know id have to source an ECU etc form somewhere but thats not a problem as my mate breaks GTis as a hobby ans hes got about 5.
im worried about driveshaft lengths, engine mounts etc... any ideas guys?
cheers
lofty
Posted: Fri Jun 09, 2006 1:33 pm
by Gallagher
lection: the 801 small polo engines lean forwards.. the larger 827 golf engines lean backwards.. they du not fit in any way without buying a salzmann sub-frame or welding in new engine mounts..
Posted: Fri Jun 09, 2006 1:39 pm
by Shaheen
Hey dude....I'm also looking for info on changing the motor in my MK2....I wanted to fit a 2.0 8V long block motor but the guys say that the motor will be too high....
I think we need tofind 1 guy thats done it just for a few ideas and then all will be cool.....I really wanted to fit a 16V motor but the head looks like its gonna be way too big in that engine bay.
If you do get any info please send me some.
My e-mail address is: [email protected]
Shaheen
Posted: Fri Jun 09, 2006 2:24 pm
by Gallagher
ok, let me try again :) the big engines: typ 827 - the eninges used in golfs mk2 and such does not fit in the polo.. the axles will be allwrong.. unless you weld totally new engine mountings.. or buy a salzmann sub-frame..
Posted: Fri Jun 09, 2006 2:44 pm
by Shaheen
i know that new engine mountings will have to be used. On a previous post of mine some of the guys have said that some of the Germans have done it before. But i cannot find any info on it.
Posted: Fri Jun 09, 2006 3:56 pm
by Gallagher
of corse it is possible, but it's a good heap of work..
Posted: Fri Jun 09, 2006 6:17 pm
by chris_lofty
sounds like a challenge, anybody see that belgian/dutch (dunno which) mk1 in baby blue where the guy kept the engine lid slightly open from the windscreen side just to let the new engine sit in place, id do that if i had to...
so what do you reckon, worth it for the work needed or not?
all i need to know
lofty
Posted: Fri Jun 09, 2006 7:06 pm
by Gallagher
really not.. at least not if you not a proffesonal..
Posted: Fri Jun 09, 2006 8:55 pm
by Tahrey1043
fraid anything above a 1.4, or a short block 1.6, hasnt a hope without heavy work upfront, or heavier work to midmount it (losing your rear seats and boot in the process). its just too big for that small, low engine bay. sorry! turbo modding the thing would probably be as effective and slightly easier... and i dont even think ive seen that done ;)
besides as the golf is slightly wider, shafts supplied may be too long... may be able to use your existing ones if youre deadset on the idea
Posted: Fri Jun 09, 2006 9:36 pm
by Gallagher
the main issue is not that the engine is to big, but since the larger 827 engines are leaning backwards, the axle mountings will be way ti high in the engine bay when mounting it into an 801-enigne bay, with engine placement leanings forwards.... so you would have to weld all engine mountings over again.. and the 801 transmission box does not fit the 827 engines.. do you understand ?
Posted: Fri Jun 09, 2006 10:41 pm
by SteB
Just gone on ebay.de...
http://cgi.ebay.de/Polo-Salzmann-Hilfsr ... 8069729658
1k Euros.... jeeez, thats a lot of money that could be spent inserting and tuning a small block
Posted: Sat Jun 24, 2006 6:14 pm
by TheFog
more on this subject:
Posted: Sat Jun 24, 2006 6:17 pm
by TheFog
