Page 1 of 2
QUICK HELP NEEDED WITH INDUCTION KIT QUESTION>>>>
Posted: Fri Jun 09, 2006 11:58 pm
by 1stcarsapolo
I currently have a drilled airbox in my 1.0 litre 8v polo 6n.
Sounds good for a free modification ......... but i was up in Halford the other day and seen a universal fitting mushroom shape Ripspeed induction kit for just forty euro. I was thinkin of getting it to check it out because it was so cheap. It would no doubt fit under the bonnet and it said it fitted throttle bodies(think that is the right word) down to 60mm.....
I was just wondering what size is the 1.0 litre polo one and would it fit?! Also I dont know if I would have to do anything with the oil breather pipe?! not sure if there is a pipe for it on the induction kit..... if not what do I do?!
Quick replies wiould me much appreciated as I have a brief window to get to the shop tomorrow morning durning my busy weekend as it's quite a drive away.
THANKS ALL!
Posted: Sat Jun 10, 2006 10:38 am
by dragon_green
i think most people take the breather pipe off when they put an induction kit on.
Posted: Sat Jun 10, 2006 10:40 am
by 1stcarsapolo
take it off completely or just leave it loose?! Dunno if that could be too good for it. Ive seen tiny cone filters around too I thought I might need to put one of them on the end of the pipe.
Anybody else any idea???
Posted: Sat Jun 10, 2006 12:12 pm
by dragon_green
1stcarsapolo, this is my understanding of the breather system:
-Some exhaust gas will always escape past the piston rings into the crankcase.
-As engine speed increases, more gas (products of combustion) will escape into the crankcase, increasing pressure in the engine block.
-The aim of the breather is to direct these gasses out of the engine block, and back into the cylinders so that they can be ejected from the engine via the exhaust. It is a method of emission control.
-However, oil is being distributed inside the crankcase. You don't want oil going back into the engine (because then you'll be burning oil which would make the emissions very bad, and more oil top-ups are needed).
-There is a filter at the base of the breather system to stop oil going back into the top of the engine.
Posted: Sat Jun 10, 2006 9:52 pm
by 1stcarsapolo
Firstly i would like to appologise as i am slightly drunk writing this but i still love my polo and lovce talkin about cars....Sound man thanks. I was off on the seacrh for a universal filter today. Found a few possibilities.... some mushroom shaped ones... I chose these as they would fit under the bonnet. Still not sure about the trottle body diameter and what adaptor I would need..... Think its about 55mm/60mm... Anybody help?! Cheers
Posted: Sun Jun 11, 2006 12:55 am
by Ant_6n
i bought a universal filter for about £15 i just took out the panel filter from the airbox then fitted the air filter to the end of the feeder hose that goes to the air box. sounds good all i need is to fit the cold air feed and bodge up a heat shield cos where it sits is right near the manifold, near the right side headlight.
Posted: Sun Jun 11, 2006 6:02 pm
by BLACK6N_POLO
do u have pictures of this please mate!
Posted: Sun Jun 11, 2006 6:51 pm
by polopowah
don't leave the hose just dangling!
it will p*ss oil after awhile as i found out!
you'll need to get yourself a universal breather filter to fit on the end
-Ben-
Posted: Sun Jun 11, 2006 9:07 pm
by Ant_6n
BLACK6N_POLO wrote:do u have pictures of this please mate!
who was this directed at? if it was me ill get some pics up soon ive got one of those universal induction kits in the for sale section.same as mine just diferent colour.
ant
Posted: Sun Jun 11, 2006 9:10 pm
by BLACK6N_POLO
ye sorry if i was unclear it was directed at you mate (Ant_6n) -- i would like to see the universal filter on the end of the standard air box please
Posted: Mon Jun 12, 2006 7:58 am
by polo boi
1 of these man waz it u were lookin at, the oil breather pipe connects in2 the bottem of it via a pipe leading out of the K&N, im not sure wot diameter this is, but u just replace the whole air filter with this.
Posted: Mon Jun 12, 2006 11:46 am
by BLACK6N_POLO
cheers for that picture mate -- but i wanted to see the filter connected to the standard air box.
i believe the way shown in your picture above- the filter is just sucking in hot air- a heat shield and cold air feed should be added in
thanks for tht mate
Posted: Mon Jun 12, 2006 3:06 pm
by polo boi
yea if u want an induction kit, the standard air filter stays on an the pipe leading out from the side of it is where the induction pipe fits on2, theres a guy in the forum that has it done, its either, jay or RR Livi
Posted: Mon Jun 12, 2006 4:57 pm
by Ant_6n
this is how ive got mine fitted
coincidentally ive got a few of these for sale if anybody is interested for £20 posted can get them in chrome blue or red.
cheers ant
Posted: Mon Jun 12, 2006 5:50 pm
by RR Livi
lol same as me :D
