Trouble starting
Posted: Mon Jun 19, 2006 8:38 am
by Vickie
Since Saturday she hasn't been starting well without revving her a load. She just cuts straight out, even with clutch in etc. Any ideas what it could be? :?
Posted: Mon Jun 19, 2006 9:34 am
by polo boi
ive asked this to loads of peeps about this as i had the same problem, pop ya bonnet an look at the master cycliner, theres a black pipe which comes out from it, make sure this is pushed on properly, u may hear hissing if so this is ur problem, with this pipe bein loose ur engine dosnt idle right or start at all at times, i had this problem an found this pipe sittin out an pushed it on an wayhay i was away, hope this is ur problem an nuthin major
Posted: Mon Jun 19, 2006 10:19 am
by Vickie
thanks for the advice - i'll have a look later :)
anymore ideas guys as to wat else it might be?
Posted: Mon Jun 19, 2006 5:07 pm
by Stacey_K
Had a similar problem with mine, difficulty starting and running in general:
http://www.tigerstyle.co.uk/poloforum/v ... hp?t=22688
Good Luck with ur's
Posted: Mon Jun 19, 2006 9:32 pm
by Polo Paul
As in previous post make the throttle body your first point of call.
