More Idle Issues...
Posted: Tue Jun 20, 2006 2:41 pm
by Stacey_K
Since my last post the car now starts fine, the problem now is that the car revs itself at junction. The worst thing is that it now seems to increasingly stutter alot while driving, feels like when u let go and re-apply the throttle during driving.
Upon inspecting the throttle body today i noticed that the small rubber pipe connected to the bottom of the air box has a hole in it and the rubber is not in good shape. So im guessing this is the 'oil breather' pipe i have read about in other posts, if so could this be causing my idle symptoms (save me getting a throttle body), and where do i order a replacement....thanks in advance...
Posted: Tue Jun 20, 2006 5:33 pm
by dragon_green
what size is the pipe?
the oil breather pipe is normally quite big (approx 20mm outer diameter?), and I'm not sure that a knackered breather pipe would affect your idle. it could be the vacumn pipe though, they're quite a bit thinner than the breather pipe.
Posted: Tue Jun 20, 2006 5:47 pm
by Stacey_K
top of the hose fits over plastic pipe at bottom on air box (i'd guess around 1-2cm in diameter)...Cant get at the other end, but it looks wider. Soz i havent got a haynes or anything to inspect...any links to online images??
Posted: Tue Jun 20, 2006 5:57 pm
by the mint with the hole
yep, vacum pipe, fits into the bottom of the airbox, tniy little pipe, jst get down to vw and get one ordered, bout 4 quid. problem solved...
Posted: Wed Jun 21, 2006 4:47 pm
by Stacey_K
Sorry guys but im getting a bit confused and just want to make sure i get the right pipe from VW...
The airbox only seems to have 3 holes, 1: the large plastic air intake, 2: the round seal that sits over the butterfly valve and 3: the pipe i need to replace... So soz to waste anyones time and look an idiot but from what i can see it can only be either the oil breather OR the vacuum pipe and from the feedback im getting it could be either but i only see one pipe. Sorry if this doesnt make much sense, thought it might be the oil breather as it looks like old dirty oil inside maybe, but hoping it might be the vacuum pipe as this could solve my problems...
Any help or p*** taking this way please....
Posted: Wed Jun 21, 2006 5:22 pm
by dragon_green
you should have these pipes connecting to your airbox, aside from the 'air in' pipe, of course.
Posted: Wed Jun 21, 2006 5:34 pm
by Stacey_K
Thanks for the pic, well its def the oil breather pipe that has the hole, but on a more worrying note the vacuum pipe is not connected up???? Hasnt been for a while. When replacing the airbox a while back i checked for any missing pipes and didnt see it, I cant check(fix) now as the misses has taken her to work 2nite....
Posted: Wed Jun 21, 2006 9:57 pm
by dragon_green
that could be your problem then :)
Posted: Thu Jun 22, 2006 3:42 pm
by Stacey_K
Just taken the air box off, no vacuum pipe to be seen like in the pic posted...Plus the airbox doesnt seem to be missing any pipes...Its a 1.4 8v.
Am i missing something obvious here?? Cheers for the help
Posted: Thu Jun 22, 2006 5:02 pm
by dragon_green
i've got the 1.3 8v which was the predecessor to the 1.4, and that has one. can't remember where on the airbox it goes, sorry.
Posted: Thu Jun 22, 2006 5:33 pm
by willy g
I aint got one either ive got the AEX engine , i read about it in the haynes manual when i was fitting my k an N filter but it was,nt there.
