plug behind the ash tray?
Posted: Wed Jun 28, 2006 7:26 pm
by titch
i pulled the wee ash tray bit out thats next to the lighter and seen a wee plug behind it - any one know what this can be used for? thanks
Posted: Wed Jun 28, 2006 7:31 pm
by polo power
its an obd 2 connector for when you want your cars computer 2 check for fault codes dealerships use it. hope this helps
Posted: Wed Jun 28, 2006 7:32 pm
by ModifiedMadness
It's what the VAG Com plugs in to mate
Posted: Wed Jun 28, 2006 7:57 pm
by titch
orite, thanks
Posted: Mon Jun 30, 2008 5:18 pm
by DanOliver
Out of curiousity, is it possible to get a plug for this and run it to a computer at home? so I can check for faults myself? as the garage I got my car told me there are no faults, but I do not quite believe them
Posted: Mon Jun 30, 2008 5:52 pm
by Ian_R
You need a laptop and a Vagcom Cable, which you can buy off the Bay, think it will come with an Early version of vag com, then you plug and Play.
But be warned about f*****g about with it, can wreak havoc if you aint carful!
Posted: Mon Jun 30, 2008 5:59 pm
by DanOliver
Sweet
ok I will look into that. I probably won't buy one as I will more than likely press something curiously and break it
Posted: Mon Jun 30, 2008 10:16 pm
by 3LL1077
Oh i didnt know thats where it plugged in
Learn something new every day
Posted: Thu Jul 10, 2008 9:09 am
by Dougie
You can definately get the equipment to do it, but it will cost you an arm and a leg!
Posted: Thu Jul 10, 2008 5:49 pm
by DanOliver
why will it? I bought the VAG-COM lead from ebay for £13 which cam with some evaluation software and drivers for both windows and mac :/ I know the evaluation software won't go into any details if there is a fault, but at least you can see if you have any faults
