getting door cards off?
Posted: Mon Jul 03, 2006 8:58 pm
by titch
how do you do it?
my passenger side door doesnt open from inside now so need to get the door card off to try and fix it, but how do i go about getting it off?
thanks
Posted: Mon Jul 03, 2006 9:12 pm
by MaxZ
you wont believe how many times this has been posted!
undo the screw next to tweeeter,
take out the door pin by unscrewing it..
take out the door handle and you;ll find 2 more screws
after that go round the card with a screwdriver carefully unclipping the clips around the door card and it should come off after that
Posted: Mon Jul 03, 2006 10:08 pm
by titch
yeh ive posted this before but i didnt understand it the last time, and dont really understand it now either
tweeter?
Posted: Mon Jul 03, 2006 10:28 pm
by titch
right got it off, im guessing you jus peel the foam stuff off now
Posted: Mon Jul 03, 2006 10:34 pm
by MaxZ
for the tweeter there's another screw you undo that and it comes out.. make sure you unplug it.. then u can just force the tweeter out.. most of the aftermarket tweeters go in with a very tight fit so no need for glue
Posted: Mon Jul 03, 2006 10:35 pm
by titch
anyway i got the door card off, and now the handle can move further back it can open the door
Posted: Mon Jul 03, 2006 10:53 pm
by Del_GTi
Sounds like a connecting rod has been bent if the handle needs 2 be pulled right back to open the door.
Posted: Mon Jul 03, 2006 11:19 pm
by titch
Del_GTi wrote:Sounds like a connecting rod has been bent if the handle needs 2 be pulled right back to open the door.
and whats a connecting rod?
Posted: Mon Jul 03, 2006 11:26 pm
by Del_GTi
It's a rod which connects the door handle to the latch/lock mechanism inside the door.
