Cough splutter it's supposed to be a GTI!! help!
Posted: Wed Jul 05, 2006 6:32 pm
by RACINGGTI
Fault code: 17927 - VVT Intermittant Malfunction Bank 1
Autodata diagnosis: Camshaft position (CMP) Control B.1; possible causes: Cylinder head oil pressure too low, CMP Actuator Sticking/defective
Help needed to diagnose a bad splutter a low end (up to about 3k rpm). I've changed plugs, new panel air filter (K&N), new cam shaft position sensor, VW have checked Lambda sensor and it's fine, said throttle body needs a clean but not what the problem could be? Getting some oil through the breather pipe (back pressure???). Puzzled as to what it could be and would love to find the fault! I don't fancy paying VW any more money to find something they can't even identify!
Posted: Wed Jul 05, 2006 6:39 pm
by Ross Clarke
Not had that exact fault but it looks like its down to the variable valve timing operation.
Have you had a timing belt changed? Is it near the time to have it replaced? Any noises from that area?
I'll have a word at work and see if i can dig anything up. Also try a google search on that number, might get lucky.
Posted: Wed Jul 05, 2006 9:42 pm
by RACINGGTI
I't just about due a service and would probably be the toothed belt change. I sometimes hear a bit of a metallic ring if revving and allowing to idle (usually about 2500 rpm) That's not the idler arm on the way out is it?
17927 P1519 Intake Camshaft Contr.,Bank1 Malfunction
According to all code reader specialists?? any ideas what i've not done correct?
Note; there are what appears to be two sensors on the top of the engine. One to the right (cam shaft position sensor) a three pin unit that is screwed to the block. The other is situated on the left and appears to have metal legs holding it in place. It is larger and has a two pin electrical contact? What is this and is it another sensor that I perhaps have overlooked?
Posted: Wed Jul 05, 2006 9:44 pm
by Ross Clarke
RACINGGTI wrote:any ideas what i've not done correct?
How do you mean?
Posted: Wed Jul 05, 2006 9:51 pm
by RACINGGTI
I'm guessing that by changing cam shaft sensor I've done what it says is the fault recitfication, Plus all the other things that I thought might solve it such as test the lambda and put new plugs and air filter? non of which have solved it?! BAFFLED
Posted: Wed Jul 05, 2006 10:07 pm
by Ross Clarke
It sounds like a fault with the variable timing unit not the camshaft sensor.
Is your oil level ok?
Posted: Wed Jul 05, 2006 10:18 pm
by RACINGGTI
Ross Clarke wrote:It sounds like a fault with the variable timing unit not the camshaft sensor.
Oil level seems fine. It had lost some a while back but since changing the components listed earlier I've had no great loss of oil?
I've started thinking along the same lines as you but... where is the VVT control unit housed?
Plus when anyone refers to the bank 1 part of the fault code they say it's the lambda sensor???
I'll have to pressure test to see if it's a piston ring or something but don't think it's that!
Posted: Wed Jul 05, 2006 10:22 pm
by Ross Clarke
Bank one is just a default code.
Its used for when you have a V engine, then you will have lambda probes, VVT units etc for both banks. It just lists them as bank 1 and bank 2 so you know which one they are on about. For inline engines they use the same codes, its just they only have 1 bank.
Posted: Wed Jul 05, 2006 10:29 pm
by RACINGGTI
If you have any more thoughts i would love to hear what you think coz this one has me and everyone I've told about it, absolutely stumped!
PM me if you can. Many thanks!
Posted: Wed Jul 05, 2006 10:30 pm
by Ross Clarke
Im a technician at a VW dealer so I will have a look on ELSA tomorrow and see if I can find anything helpfull for you.
Posted: Wed Jul 05, 2006 10:43 pm
by RACINGGTI
Appreciate that mate!
