mk3 gt
vikash
mk3 gt
Post by vikash »
can anyone help?
ive posted on clubpolo but no reply..
my car stopped after a lot of hassle it turned out to be the igntion coil... but along the way to fixing, the car stopped priming the fuel pump and it wont start unless the fuel pump is manually connected... bought both the relays near the ecu and it still doesnt prime....or start unless manually connected...
i think its the ecu so am on the look out for one...
if anyone knows what part in the ecu that needs replacing (i think it is transistor 3) then please let me know so ill replace and test....
thank you for any help
pettsy
Moderator
Post by pettsy »
Have you checked all of the fuses?
vikash
Post by vikash »
yeah i checked and double checked all the fuses in the fuse box... i take it that is the only place for the the fuses...
also the relays near the ecu are the only ones for the engine?
thanks
