Grinding noise when driving…help?
Can anyone help with the below? I am off work next week so will get it booked in, just wondered if anyone has a similar problem and what it turned out to be?
When driving (in gear at any speed) I get a light grinding noise from under the car (could be clutch / gearbox area). It gets nosier as I accelerate until the engine note is loud enough to override it.
If I take the car out of gear the noise disappears completely (I can move the clutch up and down without any noises too)
The clutch seems fine, as does the gearbox, gear changes are sometimes rough / clunky but I believe this is a normal for gti.
Anyone know what it could be? Hopefully it’s a cheap fix.
Thanks in advance,
Joe
Thanks in advance,
Joe
- Sponsor
I think it does get louder, will go for a drive in a min...cjwardy wrote:sounds like your gearbox mate.
mine did it a few weeks back now.
does the sound get worse in 3rd & then more so in 4th?
Mine was a gear linkage. Get it to a VW specialist asap
Can i be rude & ask how much it cost you? pm me if you like?
EDIT - Thanks for all the comments so far
Nah revs make no difference, tbh the sound is not that bad, but i know i can hear it! It comes and goes, like yesterday i went for a little drive to check if it gets louder in certian gears....and it didn't do itPetrified wrote:does it only happen at a certain rpm??
like 4000-5000rpm ?
Another thing I forgot to add, sometimes the car feels very jerky, just driving along with my foot lightly on the accelerator, sometimes it will start jerking like I am tapping on it.
I think all GTIs are very jerky like that, well mine certainly is.
Cost of the recon on my box was £450!
Best advice is to get to a garage soon to check it.
The noise isnt very loud, but noticeable enough.
I could also feel it through my pedals.
When you get the noise try dipping the clutch & see what happens to the noise
I'd be still erring on the side of it being a clutch issue. The noise is the same for me if the clutch is down or up. The only difference is that mine gets louder when accelerating harder. Also my clutch judderes, so might wana see if yours does that too. That noise that your hearing is common to most cars btw, its not the GB - you'd know if it was becuase you would find it very very difficult to get in 4th, if it was buggered. Gear changes for me are very smooth - can easily go into 1st from 20mph and I'm getting the same noise
Sorry to keep posting,
I actually think im wrong lol! Mine is different to what your describing JKM, I have realised. Mine makes this noise when warmed up, every time I drive, the noise is exactly the same in all gears, only time its changes is when accelerating. The noise sounds like buzzing, not grinding. Gear changes are easy however when you ride the clutch(I did this to check if it was clutch prob of GB prob) it makes a more buzzing sound. So maybe the prob is the GB I'm no mechanic.. clearly
Try riding the clutch whilst the window is down - if it makes more of a noise than when in clutch is full engaged then that would indicate clutch rather than GB, anyone second that?
My GTi was doing it especially in 2nd and 3rd gear when you accelerate and take your foot off to let the air run through. Took it into VW and they said the middle bit of the exhaust needed repairing so they replaced it even though my Dad said it was just some plate to do with the exhaust which was loose but we weren't gonna argue for a new free exhaust.
And yep...the noise was still there when we drove it out. Finally they listened to my Dad and just tightend up that plate which was rattling and the noise has gone away.
