Rear Bearings
Posted: Tue Oct 17, 2006 9:07 pm
by Coops
i take it the rear wheel bearing is built into the rear drum housing on my mk3 1.3 cl? when i had it apart other day (handbrake cable snap) i noticed a second smaller bearing that also slots into the drum once its on the car and is then held by a nut and split pin/cap assembly. which parts do i need to change? and how much?
whats the easiest way n all, take drum off and take it away to get the bearing pressed in?
any advice more than welcome!
cheers
Coops
Posted: Tue Oct 17, 2006 9:55 pm
by Mk2Adam
that smaller bearing held on by the castle nut and split pin IS the rear wheel bearing mate, no pressing to be done.
all you need to do is just swap the bearing and put it all back again with a new split pin :wink:
don't think the rear bearings are too expensive either too 8)
Posted: Tue Oct 17, 2006 10:38 pm
by Coops
bloody hell! :shock: its tiny! how the hell does it not give up every 100 miles! :lol:
ones on my clio are press fitted to the rear discs and massive compared to that thing! :oops:
Posted: Tue Oct 17, 2006 10:39 pm
by Coops
lovin the signature pic n all, mk 2 c4! :P
Posted: Tue Oct 17, 2006 10:52 pm
by Mk2Adam
Coops wrote:lovin the signature pic n all, mk 2 c4! :P
i'll have to update that now that i've got my G40 too now 8)
Rear wheel bearings
Posted: Sat Nov 04, 2006 10:00 pm
by buster.g40
SKF part number for rear wheel bearings is VKBA529 :wink:
