UK-POLOS.NET - THE VW Polo Forum • Booked the polo in for a cambelt change.
Page 1 of 2
Posted: Wed Nov 22, 2006 6:16 pm
by Petrified
The FSI was booked in for a cambelt change today, it's on 46,000 miles now. got to the garage, left the car. an hour later aget a phone call and told that it's chain driven and doesnt need replacing for another 40,000 miles.
:shock: never knew that! :lol:
and nor did vw by the sounds of it :roll:
cheap round :P
Posted: Wed Nov 22, 2006 7:28 pm
by dino
Is that because it's and FSI or generally the 9n has a chain driven?
Mine needs doing soon ie asap
Posted: Thu Nov 23, 2006 1:35 am
by Petrified
just the 1.4 fsi.
im just supprised as I assumed it was a belt
Posted: Thu Nov 23, 2006 10:28 am
by M7
im pretty sure they are all chain driven as my timing chain slipped! check my post in here
http://www.tigerstyle.co.uk/poloforum/v ... 410#193410
the chain slipped a few teeth knocking the cams out of sync...if that makes sense
*i f'all about engines, so i hope this is what you mean :lol:
Posted: Thu Nov 23, 2006 9:30 pm
by Spammy
I've been told by VW my cambelt needs doing within the next year. So I presume they're right... :?
Posted: Fri Nov 24, 2006 11:55 am
by alanred
I took mine to the dealer i got it from for a service and cambelt change back in August, they told me it needed the cambelt changing at 40k and quoted me £370 :shock: I took it to a different dealer and they told me it doesn't have a cambelt, it's chain driven which only needs attention if it's slipped, just out of curiosity i phoned 2 other dealers and they said the same....chain driven. It just confirms what i always knew that Gilbert Lawton Manchester are complete tossers who only want your money for nothing in return, also told Vw uk about what they said, still waiting for them to ring me back, it's only been 3 months :o
In the end i took it to Vw Bury and got a service for £125. G.Lawton wanted £180....joke !
As for the top speed i've never floored it...sorry.
I'm getting 94 miles out of £10 around town....not bad really.
Posted: Fri Nov 24, 2006 5:22 pm
by darkman
My 1.9 TDI had the cambelt changed in july as per 4 years or 60,000 miles. These engines have a cambelt. The 1.9, correct me if I'm wrong, is a 30 year old design. The more modern engines must be chain driven then or am I talking nonsense :?
Posted: Fri Nov 24, 2006 6:29 pm
by Buzby
On the 1.9tdi's the cambelt has to drive the pd injectors which operate from the cam. So this puts the belt under more strain than on a normal engine. Probably one of the reasons for going to chain driven cams is down to extended service intervals..
Posted: Fri Nov 24, 2006 7:22 pm
by dino
VW Dunstable tell me my 1.4 tdi MY02 is belt driven - will have to ring around (hoping it's chain driven lol)
Posted: Fri Nov 24, 2006 7:42 pm
by AKs_SlickPolo
I'm sure its quite easy to check yourself on petrol engines (possibly the same on diesels), just need to unclip the two clips on the cover and you can see it? Probably have a look at mine tommorow.
According to VW mines due, so would like it to be chain driven too :D
Posted: Fri Nov 24, 2006 7:59 pm
by Goosey
Had my cambelt replaced at 60K (no chain) for 1.4 TDI :cry:
Posted: Fri Nov 24, 2006 8:18 pm
by logistix
all TDIs are belt driven, the belt is visible if you remove the engine cover. I didn't know about petrol engines being chain driven though.
Posted: Sat Nov 25, 2006 3:53 pm
by AKs_SlickPolo
Had a look at mine today. Took less than 2mins to wip the cover off. Mine is a Timing belt :cry:
At a guess, I think only the FSI and the 3 cylinder 1.2's would have a timing chain as they are newly developed engines, as opposed to diesel engines and the 1.4 75/100bhp ones.
Posted: Mon Nov 27, 2006 3:32 pm
by Diesel_Rally
Yup, my 1.4tdi had its cambelt changed at 36K!! All under warantee though, phew. :D
Posted: Mon Nov 27, 2006 4:17 pm
by dino
Diesel_Rally wrote:Yup, my 1.4tdi had its cambelt changed at 36K!! All under warantee though, phew. :D
How did you manage that as wear and tear items are not covered under warranty i thought?
