before anyone asks, yes i have searched the forum and there are mixed answers so just need to verify this.
what size are the front door speakers in a 6n2. i believe its 16cm (i think) however i have uprated speakers so not sure if they are a different size?? can anyone confirm the size,
ive already got a set of 17cm comps so im hoping the door takes 17cm, if not its adaptors i suppose.
thanks,
6n2 front speaker size
Speaker size
I have Dynaudio MW160s in the stock locations.
They are 17.5cm according to the website, but a very tight fit. I had to file a bit off the metal basket to get it to fit inside, as there is an annoying metal bar in the way!
http://www.dynaudiousa.com/products/car/driver.htm
You should be OK with 17cm ones.
Best of luck,
Chris.
Best of luck,
Chris.
well just realised the speakers i have bought (comps) are actually 16cm, and when i removed the door card and tried to fit em, they dont fit because the original vw speakers i have are 17cm.
not very happy but thats life, are there any adaptors i can use to downsize the speakers. i need to fit 16cm speakers into a 17cm gap.
bit odd i know but it saves me having to buy another set of comps
Yeah i believe you can buy adapters mate, Best bet to google it, Also if that fails make your own with some MDFgti_black wrote:well just realised the speakers i have bought (comps) are actually 16cm, and when i removed the door card and tried to fit em, they dont fit because the original vw speakers i have are 17cm.
