UK-POLOS.NET - THE VW Polo Forum • *** Car starting Problems *** EEk !!
Posted: Sat Dec 23, 2006 1:58 am
by Arnoldo
Ok started the car tonight. Np. Then stopped up the road to pick up some m8s and turned off the car. Note that its freezing point outside*. Anyway went to get the car started and she just ticked off. There wasnt even a sign that she might start. Only got her started by rolling start. That was ok...stopped again up the road and same thing happened. M8 had jump leads and used them and they worked. I then switched her on and off and she started most times I did it. SAy 8/10 times she started np the other 2 she would just tick over.
My problem....Anyone know what could be the cause? I think its either battery or something to do with the alternator. I dont think its the temp sensor as I had that problem before and she would splutter but in this case she wouldnt even splutter. Another thing is that the battery light went on and then off as normal when placed in to third click in ignition (one before start).
Really need help on this as I need the car for crimbo :(
Posted: Sat Dec 23, 2006 1:07 pm
by alexperkins
It sounds like it could be the battery. the fact that it doesnt even try to start irons out problems with like dirty sparks and all that. Try charging it on a quick charge charger - mite fix the problem. Then, if it starts fine after that, and then begins to occur again your alternator could be to blame:P
Cheers,
Alex
Posted: Sat Dec 23, 2006 2:34 pm
by mysteryboy
Having a similar issue myself... My battery has been dead for 2 months and now I have the car back on the road but the battery doesn't seem to be charging up properly or needs more charging. If it's the battery it's no big deal... if its the alternator that needs changing it's a bigger issue.
Drive the car around for a while and see if it's recharging and check if it turns on again after a few hours... If that fails go halfords and buy a new battery and see if that solves the problem... if that fails then it's obviously not the battery so go return the battery :lol: and get the alternator checked.
(Could also be the power cable Im told but Im unsure of this one??)
(Thats what Im thinking of doing but will give it a few more days to see what happens)
Posted: Sat Dec 23, 2006 2:39 pm
by alexperkins
Someone said in a post in another thread that they replaced their battery with one for a Diesel - and said was much more reliable :p hehehe more ampage or something :D
Cheers,
Alex
Posted: Sat Dec 23, 2006 4:41 pm
by alexperkins
mysteryboy wrote:If that fails go halfords and buy a new battery and see if that solves the problem... if that fails then it's obviously not the battery so go return the battery :lol:
Hehe - didnt read that very well earlier. Last week I bought a new battery for my dads van (a VW transporter), and it wasnt needed in the end. The alternator had packed up - well it was 16 years old hehehe.
Halfords wouldnt take it back :( Pretty miffed at that
Cheers,
Alex
Posted: Sat Dec 23, 2006 8:39 pm
by Arnoldo
Starting 100% all day today. Got another problem tho. Some asshole hit my car today and a possible bent axle is on the cards as theres somin rubbing against the disks :( . Are axles expensive to fix or replace and are the parts easy to get a hold of? What a s**t Christmas :(
Posted: Sat Dec 23, 2006 10:56 pm
by alexperkins
dude thats gotta suck - i know what it feels like. I know from friends that you can get the bits to fix it from VAG parts, but not a clue on the costs :P
Cheers,
Alex
