Page 1 of 2
changing bulbs in a mk5 6n2
Posted: Wed Jan 03, 2007 6:38 pm
by vwdan
Sorry if I have the wrong forum but is there a tutorial anywhere showing how to change the front bulbs in a mk5 6n2?
It seems silly but they seem quite fiddly to change. the right one can be done just by shifting the battery a little but the one on the left looks impossible.
Re: changing bulbs in a mk5 6n2
Posted: Wed Jan 03, 2007 10:01 pm
by Arnoldo
vwdan wrote:Sorry if I have the wrong forum but is there a tutorial anywhere showing how to change the front bulbs in a mk5 6n2?
X2 !!! I have indicators that need to go in on mine and I give up after about 5 mins of hopeless trying
Posted: Wed Jan 03, 2007 10:36 pm
by ModifiedMadness
Front indicators are about a 2 minute job mate, you'll be suprised how easy they are.
Check this out
http://www.tigerstyle.co.uk/poloforum/v ... hp?t=23920 and scroll down until you see the bit about removing the indicator lense.
Posted: Wed Jan 03, 2007 10:55 pm
by vwdan
cheers
would be so easy if it was just a case of sliding off the back casing, changing them then putting the casing back on lol
Posted: Thu Jan 04, 2007 9:37 am
by Bepe
i have that same problem mate by having to remove the battery! makes a 2 minute job a 10minute job if it wasnt for the battery in the way on the passenger side!
Posted: Thu Jan 04, 2007 6:00 pm
by loud
i'd be more inclined to remove the indicator than the battery, it is only held in by one bolt
Posted: Thu Jan 04, 2007 6:14 pm
by jonnopolo
I've changed all front bulbs by removing the indicator lens first. You can then get your hand in round the back quite easily. No need to remove battery!
Posted: Thu Jan 04, 2007 9:33 pm
by polo power
the indicators arnt hold in by bolts its just a plastic clip pull it up and slide out easy as that!
Posted: Thu Jan 04, 2007 9:54 pm
by loud
there's a bolt that joins them to the headlight iirc
Posted: Thu Jan 04, 2007 10:36 pm
by ModifiedMadness
Pretty sure there's not mate, I've never seen any bolts on mine and have had them out a few times.
Posted: Thu Jan 04, 2007 10:38 pm
by jonnopolo
On MK4's there's a nut to undo in order to take the indicator lenses off, but definitey not on MK5's.
Posted: Thu Jan 04, 2007 10:56 pm
by polo power
ye thats wot i fort as i have changed both front indicator bulbs and fitted a indicator repair kit
Posted: Fri Jan 05, 2007 1:17 pm
by loud
ah right must be gettin confused with my old mk4
Posted: Fri Jan 05, 2007 5:23 pm
by polo power
Posted: Fri Jan 05, 2007 6:04 pm
by Arnoldo
Done it today. Piece of p*** when u know how ti
