Irritating noise.......
Posted: Tue Jan 09, 2007 9:39 am
by clees
Hi folks,
I have just discoverd a really irritating noise which seems to be limked with the fan on my climate control. If the fan is on as normal there is a kind of tapping noise which seems to be behind the glove area, but if i turn the circulation button on it stops???
Any ideas??
Posted: Tue Jan 09, 2007 10:09 am
by olop_chris
Yeah it does that for me also, its just normal id assume.
I dont even like climate control lol, id much prefer the A/C controls.
Posted: Tue Jan 09, 2007 10:17 am
by Ry`
Mine does it too... :)
Posted: Tue Jan 09, 2007 10:24 am
by clees
But is the noise pretty loud because it is in my car?
It's like a motor is stuck or something?
Posted: Tue Jan 09, 2007 11:39 am
by Dangerous Dave
If its pretty loud sounds like one of the flaps that directs the air to the different vents is jammed and the motor is attempting to move it causing the noise. Easy enough to fix from what I have heard however you need to take parts of the dash off to get to it.
Posted: Tue Jan 09, 2007 11:54 am
by clees
Cheers Dave, I will look into it and report back!!
I beginning to think my car has been made by a novice!! :lol:
I fix one problem and then something else breaks!! :cry:
Posted: Tue Jan 09, 2007 11:57 am
by olop_chris
The joys of GTi ownership!
Posted: Tue Jan 09, 2007 1:15 pm
by Dangerous Dave
I'm fairly certain (never done it myself) that if you remove the glove box you can get and the piping that has flap, the last time I read about this they simply removed it, lubricated it and put it back together and it worked ok. I'll try and find the post I read about it.
Posted: Tue Jan 09, 2007 1:26 pm
by Ry`
Please try and find it Dave, it might be very useful for me too :)
Posted: Thu Feb 08, 2007 10:40 am
by clees
Well i've found the problem but can't solve it. As you go under the bonnet and take out the air filter you have the section which is linked to the fan/Climate control. The flap which directs the air appears to be stuck which causes it to make a really irrating noise. Now i've been told it's not the motor....... What can i do ???
Posted: Fri Feb 09, 2007 9:12 pm
by SEXKITTEN
i seem to get the same thing.....so any help would be good. mine does it
when the climate control is off!!! really irrating :x , but i have found a cure..............turn the radio up!!!!!! :lol: :lol:
