40k service
Posted: Thu Feb 15, 2007 5:48 pm
by Mouse_GTI
My car is booked in to my local VW specialist at the end of the month for a Service and MOT. How much will a 40k service cost roughly, keeping in mind I'll need the cambelt/water pump replaced, oil change, probably new brake pads/fluid, air con regassed and my Xenons looked at.
Posted: Thu Feb 15, 2007 5:54 pm
by Bryony84
I was quoted nearly £600 for service and cambelt at my nearest dealer - so I went to my usual garage which is a vag specialist instead for a lot less.
Posted: Thu Feb 15, 2007 6:21 pm
by Mouse_GTI
I'm hoping it ain't past the £500 mark
Posted: Thu Feb 15, 2007 6:38 pm
by ModifiedMadness
My 60k one was done at VW (so more expensive) but I had pretty much what you said about (Cambelt, Water Pump, Tensioners, Discs & Pads, Oil Change and Brake Fluid Change) and it was over £500.
Somehwere around £7-800 for the service I think with the cambelt etc and £200 odd for the brakes I think.
Posted: Thu Feb 15, 2007 8:50 pm
by Dangerous Dave
My cambelt/tensioners/waterpump change was £320, 40k service was £147 as it includes changing the spark plugs, brake fluid change was £35 all from a VW dealer. The VW specialists I tried quoted give or take the same price and were further away so went with the dealer
I got the brake fluid done after I put the G60 brakes on and it sharpended them up nicely. If you just need to change the pads I would do them yourself it is very easy to do probaly save yourself £30-50 even from a specialist.
I would have thought if its all at the one time it should be around the £500 mark assuming the Xenons don't require any parts.
Posted: Thu Feb 15, 2007 9:36 pm
by oscar olop gti
Just had 60k service done, cambelt, tensioners, water pump & brake fluid
change for £550 ( £340 cambelt etc.. , £210 service) from VW stealer.
The front discs & pad wanted changing as they were 90% worn & the rears needed cleaning up as they were binding. That would be an extra £130 + VAT.
Decined their offer & bought 280mm G60 front discs, new pads & discs, pads for the rear for £150, some carriers off a friend for £20 & fitted them myself.
Just bedding them in now
Posted: Thu Feb 15, 2007 10:07 pm
by Mouse_GTI
Well what I am looking forward to is getting all the little niggles sorted so the car is perfect mechanically
