Larger throttle body
Posted: Fri Mar 16, 2007 9:10 pm
by The_phat_controlleruk
Would I be correct in saying having a larger thottle body would increase the engine's breathing so potentially increase the Bhp (albeit a very small amount), if so is there a larger throttle body that that would fit a 1.4 L APQ Mk4 polo with little hassle??
Posted: Fri Mar 16, 2007 11:35 pm
by Petrol_Head
you can pick them up on ebay.. im watching a few at the mo..
I have read somewhere that they increase your speed by 5%..
not sure how true that is. But it is something to consider... however its probably more productive to get your car tunned or look at chipping the car so the electronic processor doesnt limit the speed you can go.
Posted: Sat Mar 17, 2007 1:07 am
Any particular throttle body I should be looking at? as for chipping, I'm considering getting a remap off of the guy on Clubpolo for £120.00.
Posted: Wed Mar 21, 2007 4:00 pm
by JarnoVWPolo6N
Theoretically a bigger/wider throttle body should increase the flow in the inlet, and therefor increase torque mostly, and some bhp. But since the ports in your cilinderhead aren't made wider then they are now/originally, it won't have that big an effect. Widen the ports in you cilinderhead, then a bigger/wider throttle body will definately be "much fun"
