boot interior light.
ben3486
Post by ben3486 »
Mine doesnt work, never has since I got the car. Wondered which fuse it was as I've changed the bulb but still not working and I cant work out which fuse it is on.
Or if this is a common problem people have encoutered and theres usually another problem any help would be great!
cheers guys n gals!
The manual tells you the fuse diagram if i remember rightly :P
Cheers,
Alex
Ian_R
Post by Ian_R »
Its the tenth Fuse along the Top Row, 7.5 Amp Mate, I blow mine all the time, its not a fault its just me doing something stupid, Pick Up a Pack for a pound or something from halfords !
ben3486
Post by ben3486 »
This is the fuse box next to the drivers door right? I'll have a lil look laters me thinks n see how I get on.
cheers lads.
Ian_R
Post by Ian_R »
ben3486 wrote:This is the fuse box next to the drivers door right? I'll have a lil look laters me thinks n see how I get on.
cheers lads.
That is Correct, It Should be the Small fuses and not the big Ones, As i said, Open it up, Top Row count 10 along, Little Brown Fuse, You'll be Able to tell if it's Went or Not, and fire a new One in, 7.5 Amp :wink:
Also Is your interior Light Working or Not, as when the fuse goes that light will not work either !
adamvfr
Post by adamvfr »
Yer mine doesnt work either.
I checked the bulb and its fine not blown, and dont think its the fuse as my interior light still works.
ben3486
Post by ben3486 »
Yeah same prob. My interior light works all fine and dandy but my boot light doesnt. Really doing my head in when I try and look in the boot at night haha.
Ian_R
Post by Ian_R »
hmmmmmmmm, When my Fuse goes both Lights are out, unless its a wire problem you have ? ie. theres a dodgy connection or something, check all the fuses first tho !
ben3486
Post by ben3486 »
checked the fuses....all fine. wonde what it is?! will check tomorrow if its gettin power me thinks.
one_must_fall
Post by one_must_fall »
I have the same problem. Fuse is good, Bulb is brand new and tested.
Does anyone know where the switch is that tells the car the boot is open? Under the plastic flap?
I'm looking forward to my Haynes manual...
Tim_GTi
Post Whore
Post by Tim_GTi »
yeh the boot light is a common fault with mark 5s, mine came all there but not connected up, weird!! check under the carpet dwn the side of your passenger seat, i believe there is a connector there that won't be connected. hook it up and guess what starts working.....!!!!
one_must_fall
Ill check that and let you know. Cheers.
I have tested the plug and it is receiving power though...
Am I right in thinking that a light on my dash should tell me if the boot is open? Also when I open the boot, the car automaticly locks it a few minutes after, then sets off the alarm.
Its almost like the car doesn't know the boot has been opened...
I went to the VW dealership today. A new boot light switch is about £6. But a hours labour is £95.50+VAT. And! £47.50 for a Diagnostic test. f**k that ill fix it myself. Shame ill have to get them to service it...
Tim_GTi
Post Whore
Post by Tim_GTi »
yes it does.. and those labour prices etc are ridiculous!!!!!
Bepe
Post by Bepe »
mine dont work either, if i mess about with the catch on the boot it comes on
one_must_fall
Bepe wrote:mine dont work either, if i mess about with the catch on the boot it comes on
what catch? im yet to identify the switch that turns it on...
