Will these fit...
Posted: Thu May 24, 2007 11:49 pm
by Mac_daddy
Hey, I've recently upgraded from my 6n2 to a 9n polo and need to start some modifications. Came across these on ebay and just wonderd would these fit with the tyer size of 215/45/17 with out any rubbing?
http://cgi.ebay.co.uk/17-RS6-ALLOY-WHEE ... dZViewItem
STRUCTURE: 1 Piece Cast Alloy
SIZE: 8" x 18" -
BOLT PATTERN: 5x100 5X112
OFF-SET: 35mm 45mm
FINISH: Silver
SUITABLE FOR: AUDI/VW/SEAT
Posted: Fri May 25, 2007 12:03 am
by TimGti
You need 40 profile tyres not 45 for them to defo fit without rubbing. I have 7.5 x17 with 205/40/17's lowered lots and no rubbing!
Not quite sure whether you are asking about 17 or 18's though? Dont go 18's anyway, they are too big a look a little silly IMO
Posted: Fri May 25, 2007 12:24 am
by Mac_daddy
nah not the 18" they got the info on da site mixed up but i will confirm they are 17" before i get em. so the 215/45/17 will rub on 17"'s... where can i get sum decent 215/40/17 tyers within the west midlands area, as im seeing silly prices.
Posted: Fri May 25, 2007 12:30 am
by TimGti
Mac_daddy wrote:nah not the 18" they got the info on da site mixed up but i will confirm they are 17" before i get em. so the 215/45/17 will rub on 17"'s... where can i get sum decent 215/40/17 tyers within the west midlands area, as im seeing silly prices.
Mytyres.co.uk - Im not sayin 45's will rub but you will run into problems if you lower it. Go for 215 or 205/ with a 40 profile and you'll be fine.
Posted: Fri May 25, 2007 8:28 am
by david burton
almost guaranteed to rub. 215's should have 35 profile on them.
you might get away with it if you get the 45 offset however. but the inner tyre could rub on the arch at that point.....
Posted: Fri May 25, 2007 9:25 am
by TimGti
david burton wrote:almost guaranteed to rub. 215's should have 35 profile on them.
Yeah, was trying to think what 'Ceebubya' has on his 1.8T 9N. He's defo running 215 but as you say, must be a 35 not 40 profile, my error.
Posted: Fri May 25, 2007 10:03 am
by david burton
I suppose it depends on the lowering. you could probably get away with it on stock suspension (didn't some fella have 225s or something?!), but I wouldn't be keen on making the tyres over-wide.
the offset could help out in this case - but that will only exaggerate the tyre hitting the inner arch.
you never know for sure, but I would try to stick to 40 profile or lower for 215's, and then be careful with lowering. apart from rubbing you will have speedo issues too.
Posted: Fri May 25, 2007 11:35 am
by M7
i ran 215/45/17 for 2 years, lowered 40mm and had no problems (apart from the little bolts in the arches which i removed)
SIZE: 8" x 18" -
OFF-SET: 35mm 45mm
FINISH: Silver
them in bold wont work on the polo
need to be 5x100 and et35
Posted: Fri May 25, 2007 11:47 am
by david burton
is that because 45mm will rub on the inner arch, as I'd have thought 45 might be a better option to stop outer wheelarch rubbing....
Posted: Fri May 25, 2007 12:39 pm
by Mac_daddy
Thanks 4 da advice guys.. i spoke back to the dude dats selling em and he said he will do the wheels with 205,40,17 tyers.. which im sure wont rub from what i've read. He also said that the et of the wheels is 35mm and bolt pattern 5x100.. so it looks all good to go!
Posted: Fri May 25, 2007 1:40 pm
by david burton
IMO that's the perfect size for 17's, but other opinions do vary :)
