UK-POLOS.NET - THE VW Polo Forum • JL 500/1 USERS
JL 500/1 USERS
Posted: Sat Aug 11, 2007 6:37 pm
by shakt1
JL 500/1 Amp users I need your help,
Iv just had my 2*10 JL W3 D4 and 500/1 amp wired and fitted in the trunk of my car but the bloke down the audio shop who installed it all didnt configure the amp properly and suggested I play around with it to see what suits me.
Iv tried a little but am not too sure what I should set all the settings at.I just want whatever configuration would sound the best with the two 10's in my situation.
Anyone with this amp, what do you recommend?
I have a Alpine H/U, is there any settings I should configure?
But mainly what should I set the following to?
INFRASONIC FILTER
INFROSONIC FREQ(HZ)
'Q'
BASS EQ
CENTER FRE
BOOST[DB]
AMP LP FILTER
FILTER FREQ (HZ)
INPUT VOLTAGE
INPUT SENS(GAIN? )
or any other switches etc...
Please guys I look forward to some useful insight, am dying to set it all up properly and enjoying my set up. Thanks in advance!
Posted: Sat Aug 11, 2007 7:26 pm
by ModifiedMadness
I'd love to help mate, but I'm still not good at the tech side myself :(
I see you've asked on Talk Audio though, it may be a bit quieter than normal this weekend though as there's a show on :D
They should be able to help though.
Posted: Sat Aug 11, 2007 8:05 pm
by Hardcore
what i did was turn my head unit down to minus on everything, then turn the volume up to maximum, and alter the bass tuntil it sounds good lol. but im not using your same sound system..but you knwo. myt help out.
Posted: Sat Aug 11, 2007 8:21 pm
by shakt1
Thank you to the both of you. Il wait hopefully after this eventful weekend I might get some more help, or the folks on talk audio may suggest some useful advice. Cheers guys!
Posted: Sat Aug 11, 2007 9:36 pm
by shakt1
By the way,do either of you guys use the MX(media xpander) on Alpine H/U or similiar BASS BOOST settings on your head units?
Posted: Sat Aug 11, 2007 10:36 pm
by ModifiedMadness
I run a Pioneer but I'm sure there's no bass boost used on mine.
Bass, Mid and High are all set to 0
The bloke I get all my audio fom had a play around with it.
Posted: Sat Aug 11, 2007 11:29 pm
by shakt1
ModifiedMadness wrote:I run a Pioneer but I'm sure there's no bass boost used on mine.
That confirms I shouldnt be using any extra sub boost features then. Il try and set it all up properly tomm - All of the extra bass features etc
