1997 Polo Cuts out
Posted: Mon Oct 08, 2007 4:02 pm
by Mohan
Hi there
I'm facing a problem with my polo, not sure what the acutal root of it is
or the solution.
When i'm driving and sometimes put the clutch down, with the brakes
the reving needle sometimes goes all the way to zero and the car cuts out.
Sometimes, the car saves itself, i hear like a kickback from the rear of
the car and the needle goes up, and then when idle the needel would
move quite irraticly between 8500 and 9500 revs.
I'd welcome any suggestions, cheers for in advance.
Re: 1997 Polo Cuts out
Posted: Mon Oct 08, 2007 4:47 pm
by JarnoVWPolo6N
Mohan wrote:Hi there
or the solution.
Your trotthlebody is dead, get it replaced, is a common problem on the mpi-engined mk4's
Posted: Mon Oct 08, 2007 5:16 pm
by dragon_green
i think that's 850-950 rpm, not 8500-9500, unless you have a bike engined beasty.
pedant mode off.
Posted: Mon Oct 08, 2007 9:26 pm
by The_phat_controlleruk
Easiest and cheapest thing to do first is have a gander inside and see if it needs cleaning, you will see a build up of black crap inside it. Get some Throttle body or Carb cleaner and a tooth brush/rag and clean it out. That should do the trick. If it doesn't improve, like JarnoVWPolo6N said.
Posted: Mon Oct 08, 2007 10:57 pm
by Mohan
brilliant
really appreciate it
yeah, today when i changed the sparks and air filter, i'd had a look
and there was a lot of oil around it, once i clean it tomorrow with
carb cleaner, will post an update.
this problem had be up the wall for quite some time, really appreciat it
thanks !!
Posted: Tue Oct 09, 2007 12:16 pm
by DanDiesel
this is exactly what was happening to my other halfs 1.4cl and we cleaned the throttle body and the problem has so far ceased!
Posted: Tue Oct 09, 2007 8:51 pm
by NOZ
wish I could say the same for mine
Still have the problem although its not too bad anymore, still hate having it though. Changed lots of parts and had VW and Big Boys Toys diagnose it with no signs of whats wrong!
Posted: Wed Oct 10, 2007 10:04 pm
I'll bring my laptop with VAG-COM to the next meet if it's of any use?
Posted: Thu Oct 11, 2007 12:26 am
by Mohan
Hey
I cleaned the throttle body today by spraying it with the Carb Cleaner &
loads and loads of oil came out, there was some oil residue in the air filter
box as well, cleaned that with the Carb cleaner aswell.
the small tube connecting to the air filter I cleaned that aswell.
problem had ceased instantly, and everything running fine.
thanks again
Posted: Thu Oct 11, 2007 12:51 am
by NOZ
The_phat_controlleruk wrote:I'll bring my laptop with VAG-COM to the next meet if it's of any use?
Cheers fella, i'd be very greatful. By the way off topic but check the meets section for the midnight London convoy being setup on CP (also on ere)
Posted: Thu Oct 11, 2007 10:54 am
Mohan wrote:Hey
thanks again
Nice one, glad to see it's sorted.
