Suspension problem
Posted: Sat Oct 20, 2007 6:31 pm
ok, I've got coilovers on my MK5 GTi and they have been clunking for ages, its the spring turning slighlty when i turn the steering wheel.
anyway i've been told that the spring might not be seatin the top mount correctly, so i've just had a look at the top mounts and there doesnt appear to be a recess for the end of the spring to sit in. Is that right?
Also, i've had a look at the original suspension and theres this bearing (pictured below) that looks like it sits between the end of the spring and the top mount. I can only think that this is to allow the spring to rotate smoothly if it needs to.
If thats the case, does this bearing need to be transferred over onto the coilovers?
help?
help?
