Squeaking Brakes?
Posted: Mon Dec 03, 2007 2:45 pm
by Mouse_GTI
Hey guys, I've noticed when I apply the brakes I hear a high pitched squeak for every 360 degree rotation of the wheels. Any idea what it could be?
Posted: Mon Dec 03, 2007 2:57 pm
by dino
Have you checked them for wear and tear? When were they last replaced? Discs could be getting thin and warped, pads could be low....
Posted: Mon Dec 03, 2007 3:01 pm
by Mouse_GTI
I haven't checked them in ages. How can I tell if the pads are worn? My MOT/Service was in March and I had my rear discs and pads replaced, so assuming the fronts were ok then.
My brakes have always been crap, planning on getting G60's before my next MOT/Service March next year.
Posted: Mon Dec 03, 2007 5:19 pm
by Tim_GTi
Mouse_GTI wrote:How can I tell if the pads are worn?.
I've also wondered this.....
Posted: Mon Dec 03, 2007 5:52 pm
by Si_GTi
Take the wheel off and check how much of the pad is left - obviously they wear down through use and if they're close to having 'nout left on them, its time to change!
Depends totally on your driving style but my pads last anything from 12-18 months?
Posted: Mon Dec 03, 2007 7:46 pm
by Tim_GTi
is there any guidelines in measurements or anything like there is with tyre tread?
Posted: Mon Dec 03, 2007 11:28 pm
by alexperkins
Its all in the haynes manual. Ill dig out the specs when im awake lol :P
Posted: Tue Dec 04, 2007 2:56 am
by Dee-vub
You would no if your pads are done because braking will become pretty pathetic and it will squeek throughout braking as the pad and disc hit metal to metal
Posted: Tue Dec 04, 2007 12:54 pm
by Tim_GTi
Dee-vub wrote:You would no if your pads are done because braking will become pretty pathetic and it will squeek throughout braking as the pad and disc hit metal to metal
i'd rather have a method of checking without it getting this far!! lol
Posted: Tue Dec 04, 2007 5:12 pm
by Si_GTi
The only other time I have had squeaky brakes other than worn pads, was when one of my front discs became ever-so-slightly warped...
Mouse do you get any vibration (transmitted through the steering column) under braking?
Posted: Tue Dec 04, 2007 7:52 pm
by Mouse_GTI
No vibrations at all
Posted: Tue Dec 04, 2007 8:49 pm
by Si_GTi
Is the squeak constantly there no matter what speed? Could be a stone caught in the guard that stops water and debris from hitting the disc. Although a stone in there usually makes a hellish noise! :lol:
Posted: Tue Dec 04, 2007 9:57 pm
by ModifiedMadness
Tell me about it, you'd know if it's a stone though.
As Si says, it's a hell of a noise!!
