Mrk 7 front knocking issue!!!! anyone sorted this yet?
Posted: Tue Dec 18, 2007 8:36 pm
by Ste-9n2
ive had this problem for ages now and i really need to get to the bottom of whats up!!! as i want to go lower yet! cant do it while the bloody things knockin like mad anyone help? thanks
Posted: Tue Dec 18, 2007 9:12 pm
by david burton
when is it knocking?
driveshaft on ARB knocking? if so you will need to change the drop link geometry....
Posted: Tue Dec 18, 2007 11:01 pm
by Ste-9n2
how do i do this fella thanks
Posted: Wed Dec 19, 2007 11:33 pm
by david burton
you need to figure out if that's the issue first. then buy shorter drop links or find out if you can get some?
I've heard on here that mk4 golf droplinks might work, do a forum search IIRC.
Posted: Thu Dec 20, 2007 11:54 am
by DanDiesel
i have a knocking issue which i just can't work out but, i also had the ARB knocking on the driveshaft problem aswell.
You'll be able to tell as there may be marks on the ARB/driveshafts where they are catching.
shorter droplinks would sort this problem, i got mine from Big Boys Toys.
Posted: Thu Dec 20, 2007 7:52 pm
by Ste-9n2
i got shorter droplinks with the coilys thou
Posted: Thu Dec 20, 2007 10:34 pm
by david burton
some coilies have shorter droplinks only because the mounting point is lower - FK ones for instance.
so the effective length is the same
Posted: Fri Dec 21, 2007 1:28 pm
by Ste-9n2
so therefor shorter droplinks are no use to me
hmmm when it gets a bit warmer il jack her up n see whats going on!
Posted: Fri Dec 21, 2007 2:37 pm
by david burton
errr. yes they are - you'd have to go even shorter. depends if this is the knocking issue.
