Can I split an amp power feed into two?
Posted: Mon Dec 31, 2007 8:00 pm
by alexperkins
Hi All,
Got a new active sub on the way to me. Im wondering - is it possible just to split the current positive lead going into my amp to run both the amp and the sub, or would it be too much strain on it?
Alex
Posted: Mon Dec 31, 2007 10:28 pm
by h4r1s
doesn't it just depend on what gauge rating it is? and how much watts the cable can handle? might be wrong but i would also like to know, since i don't want to be feeding another positive wire
Posted: Mon Dec 31, 2007 10:32 pm
by ModifiedMadness
I have a fused at the battery (200amp iirc) run of 0awg cabling going from the battery to a fused distribution block at the back of the car which then splits into 2 runs of 4awg cabling for the sub amp and front end amp.
So in a nutshell, yes you can
just get
yourself a distribution block.
Posted: Tue Jan 01, 2008 8:47 am
by alexperkins
where can i get these 'distribution blocks' from? Could i cheat and just use a 240v junction
Think my battery wiring is 60A fused tho ill have to check
Posted: Tue Jan 01, 2008 1:44 pm
by ModifiedMadness
