BMC induction kit questions
adam_0612
Post by adam_0612 »
i have a 1.4mpi (mk5 obviously lol) and i am just wondering if anyone has fitted one of these to theirs before, becuase it has an engine cover and i am not sure if this will have to be removed permanently!
Also does the BMC give out a good noise and also increase any performance?
Link to what i am looking at is http://www.europerformance.co.uk/pages/ ... ?id=505490
also is that a decent price?
thanks
Redline
Sponsor
Drives: BMW 128ti
Post by Redline »
Try using the search function.
Should be quite a lot of relevant information if you search "BMC" in the Mk5 section only.
h4r1s
Location: Leicester/Sheffield Drives: Polo MKV-6N2 1.4SE 16v 75BHP
Post by h4r1s »
http://www.tigerstyle.co.uk/poloforum/v ... hlight=bmc
that's a good one there...
I think he's cut the engine cover
stani540
Post by stani540 »
h4r1s wrote:http://www.tigerstyle.co.uk/poloforum/v ... hlight=bmc
Thats my car in that thread haris put up.
The BMC is well worth it i had a k+n before and its so much better!
The noise is amazing sounds really good and as for performance, i personally think it does make a difference. In a small car like the 1.4 8v you cant expect miracles but it feels like it pics up better and since fitting mine i can get an extra 10mph out of it!!!
If you are looking at getting it for the 1.4 8v i would seriously look at getting all the bits seperately! the price you have there doesn seem bad but it doesn't sound like the kit comes with anything!
i managed to sort mine out everything in for under £100!
You need:
The actual BMC CDA filter unit
Two breather filters
An induction hose (imo the best to use is a k+n which is about 70mm off ebay) http://cgi.ebay.co.uk/K-N-Cold-Air-Feed ... dZViewItem
A reducing 90 degree bend from memory i think its 50mm - 70mm but not certain
I got a silicon coupler to connect my hose to the induction kit
and you need jubilee clips!
i would definitely scout around on ebay its definitely worth it!
if you have any more q's just ask away as this is the second induction kit i fitted to my 1.4 8v so i know this area pretty well!
and the existing engine cover is actually the standard airbox and is very easy to remove i removed all the filters off the bottom of mine and then cut it up and replaced it to give a tidier look!
To add. The piping is cold air feed pipe on ebay - its not cheap, but its very very good indeed
On the MPI engines, if you use a breather filter on the pipe closest to the manifold, oil will spew everywhere and youll lose alot!, so you need to remove the one way valve from the airbox and put that on the end of the pipe. Reducing bend is a 50mm-70mm
I got my BMC for £7.50 - bargain of the century :D
stani540
Post by stani540 »
alexperkins wrote: On the MPI engines, if you use a breather filter on the pipe closest to the manifold, oil will spew everywhere and youll lose alot!, so you need to remove the one way valve from the airbox and put that on the end of the pipe.
Alex is right about that i lost alot of oil from mine! the one in the airbox is one way so only lets air in and no oil out!
adam_0612
Post by adam_0612 »
this sounds SOOOOO complicated :cry:
anyone fancy doing it for me?lol
stani540
Post by stani540 »
it really isn that complex and is so worth it!
adam_0612
Post by adam_0612 »
hmmm....maybe but ive said before im only an amateur! would probably end up with my engine hanging out of my car somehow :o
randy
Post by randy »
Might only be an amateur but i have found the guides on here VERY useful. You get a lot more pleasure when you DIY something.
And if you do get stuck... post it and there is always someone to help out. If all else fails get a mechanic to sort it.
Your not gonna know how easy it is until you actually try.
Tim_GTi
Post Whore
Post by Tim_GTi »
pay my train fare and i'll come do it for ya(Y)
search the sale sections on this forum, clubpolo and other alike, BMCs pop up all the time for good prices.
Or, there's somewhere that do the kit new (with all the bits) for around £160? i'll try find the link now
adam_0612
Post by adam_0612 »
what you meen like all the bits that stani540 mentioned a bit above
You need:
Tim_GTi
Post Whore
Post by Tim_GTi »
yeh everything bar the 1 metre of cold air feed, whcih you can get off eBay for under £20,.
adam_0612
Post by adam_0612 »
please tell me the website...i would really want to do that :D :) :D :)
Tim_GTi
Post Whore
Post by Tim_GTi »
found it!!
http://www.kam-racing.com/index.php/cPa ... /3a/page/2
looking at it now, i'm not quite so sure if you get the 90 degree bend with it or not.
its best to contact kam_racing via PM on here. He can clear everything up for you
