Black interior???
Posted: Fri Jan 11, 2008 1:47 am
by bbspolo
Had a mk 4 golf aniversira (cant spell) in at work 2 day and whilst working on it then driving it about i decided that the black interior was the nuts!
So this got me thinking would this look as good in a polo, has any1 done it before ? and could it be done?
My thinking would be that u could get the headlining dyed black (dont think they ever made a polo with a black headlining?) then get all the piler trims covered in that stuff they used 2 cover dashes in motorsport (a friend of mine has a e46 m3 and all his piller trims look like there covered in that stuff as standard and they look very cool)
Then the only bit i am strugling with the sunvisors, grab handles and rear view mirror (unless golf bits fit? then i could use aniverisery bits)
Sadly i cot way 2 much going on at the moment 2 be stripping the gti out but if i can work out how 2 do it then ill def be doing it at some point!
So any idears ppl??
Posted: Fri Jan 11, 2008 9:54 am
by 8080
I think the Lupo GTI had black sun visors - they might fit
You can get a black mirror from a 6n
I have a Bora sunglass holder in my car but it's not a perfect fit, so the grab handles are probably slightly different
I'd hate to take the headliner out- it's very fragile. Mine hasn't been right since I took it down a bit at the front to wire my new mirror. The sunvisor rubs against it now when I move it, and i was being careful :(
Posted: Fri Jan 11, 2008 10:16 am
by MaxZ
I know Carlos on ClubPolo had a set of anniversary Recaros in his GTi, but he sold the car quite a while ago. Black headlining is standard on Lupo GTis, so they have a black mirror and sun visors. Headlining you'd have to do yourself, but it's not extremely hard if you know what you're doing.
Posted: Sat Jan 12, 2008 12:39 am
by bbspolo
any1 know of a company that does the vinal type coving for mortorsport dashes? Ill try and get a quote 2 cover all the piller trims!
Posted: Sat Jan 12, 2008 10:40 am
by Mouse_GTI
I may get my headlining retrimmed in black in the future like the new Golf GTI
Posted: Sat Jan 12, 2008 12:10 pm
by 8080
bbspolo wrote:any1 know of a company that does the vinal type coving for mortorsport dashes? Ill try and get a quote 2 cover all the piller trims!
Flocking!
I knew a guy who used to have a machine for doing this. It's an electrostatic machine that makes the fibres stand on end. A race prep company should be able sort it out. I'd say it's hard to stop once you get going, flock every surface on your car
Posted: Sat Jan 12, 2008 5:38 pm
by Tom_G_SGF
my cousin has just done this in his mk4 golf to immitate the anniversary style bits, has just lightly dusted all the piller trims sunvisors grab handles and headlining in black 2k paint, and it actually looks bloody good, not bodgy at all, headlining feels a bit rough to the touch but when does anyone feel your headlining !
Cost him virtally nothing and i think i might do it on the next polo i modify.
Posted: Sat Jan 12, 2008 5:46 pm
by CymruPolo
I'm doing it when my car goes in for a re-trim sometime in the next couple of months.
Posted: Sat Jan 12, 2008 6:21 pm
by 8080
I'm thinking about this too, I have a black r32 mirror in mine now, it looks a bit crazy from the outside next to grey sunvisors
I've just had a look on vagcat.com: The Lupo grey sunvisors and grab handles part numbers are not the same as the Polo part numbers. I'd still guess they're a straight swap tho. The Lupo GTi does have a middle visor, which is good news
Then flock the pillar trims
But then spraying the roof lining, and the bits lining the doors... :shock: I don't think I could do it
Posted: Sat Jan 12, 2008 6:22 pm
by bbspolo
Well so much for not doing this for a while I went down 2 a fabric place 2day and got black fabric dye!
Flocking thats the one :D if any1 has a number for a company that does this then ill c if they will do a group discount if any1 is intrested, and if u dont fancy getting this done on your gti trims then i have loads of spares like 4 or 5 cars worth that i can get done so u can keep your gti 1s just incase u ever want 2 put it back 2 stock!
Posted: Sat Jan 12, 2008 6:25 pm
by bbspolo
no u just dye the roof lining! ive done this before and it rearly is so easy and looks stock (thats how vw do it anyway)
Then as for the door seals i was thinking get mk4 golf ones as there black and the same (just a bit longer but even new polo ones have 2 be cut when u fit them)
Posted: Sat Jan 12, 2008 6:47 pm
by Tim_GTi
so how does this flocking work exactly?
Du just spray your existing trim with special dye?
Posted: Sat Jan 12, 2008 6:53 pm
by bbspolo
no ! im not sure how they do it think they charge the trim (run a currant though it) then the matier sticks its self evenly 2 the trim!
All i know is it looks the nut ( c if u can find a pic of the inside of a m3 as all the trims r flocked in that)
Posted: Sat Jan 12, 2008 6:54 pm
by bbspolo
or go here much better explaniation http://en.wikipedia.org/wiki/Flocking_%28texture%29
:D
