Fitting Angel Eyes? Help?
Posted: Wed Mar 05, 2008 1:21 am
by racerjonzo
hey, finally got my angel eyes, just need to fit them.... had a wee look tonite but was to dark to do much. the angel eyes have quite a few red and black wires coming out from the bottom, and the connection for the front indicator is different?
can any one give advice into this?
and/or has any one installed angel eyes similar to these?
much appreciated, want them on as soon as possible, then will take pics and post em up :)
again thanks :D
Posted: Wed Mar 05, 2008 12:06 pm
by NOZ
I had the first style FK angels ONE-PIECE, which I had to get wired up professionally by an electrician cos I didn't have a clue :oops:
Anyway, if yours consists of 2 rings and a smaller light in the corners then you should have a black and red wire for each of them. Therefore you have 3 sets to wire up with the rest as you fancy. I had mine wired so the rings came on with the side light. You can have only them as side lights which look better, so wires are without connectors for your choice.
The indicator bulb holder on mine was too big for the actual slot in the cluster. I think its the same for all the old models; not sure about the new ones. I had to cut out a bit of the plastic off to get it squeezed in (never had a proper fit, just enough to stay in there).
Posted: Wed Mar 05, 2008 12:20 pm
by racerjonzo
yea sounds like the same ones, mine are one piece aswell and 3 red&black wires, and the stupid indicator bit not looking the same, so would i be better just to get an electrician to do it?
or could you get me a diagram or pic to hows urs is connected up NOZ?
one again all help very appreciated, thnks :)
Posted: Wed Mar 05, 2008 12:28 pm
by NOZ
Logically all you do is find your side light wires and link them wires up to them. Put the red ones together and attach them to the side-lights red wire (probably another colour) and the do the same witg the blacks. I'm no good with the wiring, still don't understand whichs which when I look at them; sorry.
Getting an electrician to do the wiring is best if they use proper connectors etc.
Posted: Wed Mar 05, 2008 12:40 pm
by racerjonzo
kl cheers, think al have another look see if i can understand, but the indicator coneector bit, did u just sand down the two lugs on the side to get them to fit.... or will i have to re wire them up aswell?
cheers again NOZ :)
Posted: Wed Mar 05, 2008 2:02 pm
by JoeG07
nah its really easy to do mate, the way i did it was wiring up the rings to the side lights, i got one of those things that lights up when it finds a current, about £3 from any car shop, i pulled the plug out of my lights and turned teh side lights on then u just jab the electricity finder into all the holes untill it lights up; thats your sidelights live. So u get sodler all three of your reds together and all three blacks togetehr from the angel eyes. I'm pretty certain the red is live, so you wanna cut the wire whic you know is your side lights wire a little way up from the plug, and solder this to your reds from the angel eyes. You then gotta do the same with the earth (black wires), i think i found my earth by connecting up the live then jabbing the black into every hole untill it worked, theres probably a more technical way of doing this lol. Either way, the worst you'll do is a blow a fuse. Have a crack mate, if you do something wrong just reconnect it all how it was. heres a quick diagram for ya; if you like ill get a photo of it in a couple of days. good luck mate
Posted: Wed Mar 05, 2008 2:54 pm
by NOZ
Nope you've explained it properly Joe, just how I said. The diagram shows everything properly so even i'd understand now lol
I chopped off a triangle shape from the plastic, not the lugs. Still can't get it in most times. I just try and get one lug in to hold it secure so doesn't fall out. God knows how they manage to get the size wrong on them lights and still get away with it saying its P&P unit. :roll:
Posted: Wed Mar 05, 2008 4:42 pm
by racerjonzo
cheers guys, especially JoeG, got them up and running managed to do the first one then realised yous posted up a reply, done it all right my halos are connected to the sidelights...but my sidelights are the yellowy bulbs im either thinking about disconnecting them or just getting bluey bulbs, like the xenons or HID
wat have yous done or got running?
oh and JoeG, in ur sig ur back handles looks smoothed off, photoshop or for real?
lol
Cheers again Guys 8) 8) :D
Posted: Wed Mar 05, 2008 5:30 pm
by JoeG07
racerjonzo wrote:cheers guys, especially JoeG, got them up and running managed to do the first one then realised yous posted up a reply, done it all right my halos are connected to the sidelights...but my sidelights are the yellowy bulbs im either thinking about disconnecting them or just getting bluey bulbs, like the xenons or HID
lol
lol, photoshop :wink: , maybe one day! I got from my local some blue/white ones for a couple of quid that just look pure white, good job on getting it working
Posted: Mon Mar 10, 2008 11:58 pm
by racerjonzo
Cool might invest in some bluey white bulbs then, but was thinking about just wiring it so the halos come on as sidelights then the full works with main beam, sounds most popular and looks best i think...
anyway finally got a pic up here with them on it, just in my sig...:)
wat do yous think,... apart from the immediate notice of height like a 4X4 :P lol :)
Posted: Wed Mar 12, 2008 12:33 am
by NOZ
looking good mate. If you got orange indicator bulb then get rid and replace them with silvertec bulbs.
