can this be done?
Posted: Mon Mar 10, 2008 11:50 pm
by booli
can you lower a polo with out buying new springs or collies, i know if it can be done it wont be low,
also how low can you go replacing springs on standard shocks?
thanks
Posted: Mon Mar 10, 2008 11:55 pm
by racerjonzo
i asked this a while back but all i got was, dont cut springs, get coilies if you can afford them, they'll be worth it in my opinion, but herd you can just get lowering springs which is cheaper, but as you said, not sure how long standard shocks and dampers will endure the lowerage for.
so in my opinion id say get coilovers
Posted: Tue Mar 11, 2008 12:10 am
by kipper
the only way i know of to lower the car without getting coilies or springs is to cut ur springs but its more dangerous and u can prob get them cheap now anyways so as ud have to take the springs of u might as well just replace them its safer. i heard u can go woth 50mm lowering springs with standard shocks but no lower is recommended. also that low might not be to good with the standard shocks as they wernt made for it so will ware out after a while. i got 30mm lowering springs on my car and they been on there about 3 years or more and so far so good.
Posted: Tue Mar 11, 2008 8:15 am
by polostunner
my boyfriend used to do this to save money and if you get it wrong they are soooooo dangerous.....i made him stop that now...you cna get springs cheap. mine were jus over £57 for 4o/40 from gsf!
Posted: Tue Mar 11, 2008 10:02 am
by freshblood
as u have guessed dont cut them its not only stupidly dangerous it will be a crap ride, as it will be if u buy just srpings ull be boucing all over the place, save up for a kit or coilies, as i went for a cheap kit and wish i had done that, if ur gonna do sumit do it to the nuts
Posted: Tue Mar 11, 2008 9:36 pm
by Tim_GTi
In my opinion cutting springs isn't even an option, its absolutely ridiculous. So dangerous, you get s*it handling and ride, its a total waste of time.
I wouldn't go lower than 30mm on standard shocks.
Posted: Tue Mar 11, 2008 9:41 pm
by Biddle
I wouldn't bother mate. It may seem your saving money, but in the long run bits will wear out quicker and cost money to replace.
Just save up and get a lowering lit or colies.
