Wiring headunit to switch?
Posted: Thu Mar 20, 2008 8:12 pm
by MGrove03
I recently installed my alpine headunit with bluetooth adapter which works brilliantly. The only problem is that when i switch my engine off the headunit and bluetooth adapter don't switch off. This is a bit of a pain as i have to remove power cables from the bluetooth adapter so it doesnt drain the battery.
So i managed to get a rear heater screen switch from a local scrap dealers and was wondering if it would be possible to wire up my headunit and bluetooth adapter to this so that it would act as a sort of 'kill switch' so all i have to do is push the switch to turn it on/off.
also if you can tell me what each of the wires is for on the rear heater screen switch that would be great :)
Posted: Fri Mar 21, 2008 1:48 pm
by sylvester
What year of polo and HU model? Vw use a different wiring system than the standard iso, usually there is an option on the HU wiring to swap the ignition and battery leads over. How did you connect the HU wiring?
Posted: Fri Mar 21, 2008 7:48 pm
by alexperkins
Just put it on a SPST relay that operates on the ignition live. Thatll solve all your problems :)
Posted: Sat Mar 22, 2008 11:59 am
by MGrove03
and where will i find an ignition live??
Posted: Sat Mar 22, 2008 2:15 pm
by sylvester
Much easier fixing the HU wiring than adding a relay and a switch :idea:
Posted: Sat Mar 22, 2008 6:59 pm
by alexperkins
lol the HU wiring fix usually only fixes the memory effect problem that some newer HUs face. Its worth a shot tho
Ignition live is on the back of the HU on the black block. its the Red/white chunky one :)
If you want just a trigger then its the blue grey one
Posted: Sun Mar 23, 2008 2:00 am
by sylvester
So far hasn't confirmed HU or model year but,
Does that mean the proposed fix by MGrove03 is the norm for aftermarket HU on veedubs :?
Posted: Sun Mar 23, 2008 7:00 pm
by MGrove03
its a 55 reg mk7 polo and i think it may be an alpine 9885r ive fitted quite a recent model anyway.
Posted: Sun Mar 23, 2008 10:18 pm
by sylvester
If the rcd200 was originally fitted, this lead will solve your problem, autoleads PC2-75-4, get it on ebay, you may also require an aerial amp (PC5-136) if the radio reception is poor. For the illumination/dimmer you will need a feed from the light switch or heated window illumination.
How is the HU wired at the moment?
Posted: Mon Mar 24, 2008 3:37 am
by MGrove03
i dont know what was originally fitted but the cars an 's' model if that helps. im currently using that lead to connect it also.
Posted: Mon Mar 24, 2008 8:13 pm
by sylvester
Just noticed you've already asked for help in this forum regarding the HU wiring. :?
3 choices,
If the car has a large black connector autoleads PC2-75-4 adapter
If the car has 2 connectors, 1 black 1brown :autoleads PC2-69-4 adapter
or modify the HU wiring as follows,
if the car has 2 connectors, 1 black 1 brown, using the HU wiring switch the yellow(9) to the red(6) that has the twin connectors then remove the red (6)HU wire from the twin connector and join it to the yellow (9), so the wiring is yellow to red.
Look at the wiring in the manual
Aerial adapter either autoleads PC5-136 or PC5-52 , all got on ebay.
Posted: Mon Mar 24, 2008 8:40 pm
by MGrove03
as said in my last post im using the pc2-75-4 adapter but it hasnt solved my problem
Posted: Mon Mar 24, 2008 9:51 pm
by sylvester
Doesn't tell me a lot. :? :?
Do you have a test lamp?
What you need to do is check the blue, yellow and red wires to see which one switches on and off with the ignition.Whatever wire it is, this should be in the same position as the red wire on the HU connector, then the permanent +12v should be in the same position as the yellow wire on the HU connector. Some pc2-75-4 adapters have the option of changing the wiring over similar to the HU.
