97/98 1.0L POLO OIL LEAKAGE
Posted: Tue Apr 01, 2008 11:34 am
by c.l.w.design
I have the above polo, it has recently been serviced at this point the oil was changed. For about 2 years there has been a slight oil leakage, I have had a mechanic check it and they couldn't find the source of the problem, I know its not the head gasket. I jet washed the engine and about 3-4months after this the oil came back, what could be the cause? The leakage seems to be on the bottom right-hand side of the engine.
Posted: Wed Apr 02, 2008 6:59 pm
by SpikeyG40
Hello mate, i can't really help with your problem, but i'll move this to the correct section. you have a mk4 polo, thus why your not getting many replys! :wink:
Posted: Fri Apr 04, 2008 2:49 pm
by iggy350
probably ur valve seals. if ur car blows a bit of smoke when u start it up and the exhaust fums smell funny it will prob be that. Not always a bad thing to have oil on them tbh means when ur car starts there is oil there all the time instead of a few seconds later. Less wear on them then. Or so a mechanic told me
Posted: Fri Apr 04, 2008 4:11 pm
by dragon_green
iggy350 wrote:probably ur valve seals. if ur car blows a bit of smoke when u start it up and the exhaust fums smell funny it will prob be that. Not always a bad thing to have oil on them tbh means when ur car starts there is oil there all the time instead of a few seconds later. Less wear on them then. Or so a mechanic told me
Iggy, I don't think that would make an oil leak to the outside of the engine :?
Posted: Fri Apr 04, 2008 5:43 pm
by iggy350
my bad then misread ws in a rush at work, thought he said there was no visable leak lol
