195/45/15 ATS Cups, Will They Fit My Polo?
Posted: Fri Apr 25, 2008 6:14 pm
by vw-po-low
Brought some ATS Cups. A suddent thought, will they fit alright when i use full lock? the car has standard suspension. I plan to lower, how low can i go without arch work?
Posted: Sat Apr 26, 2008 4:00 am
by Tim_GTi
They will be absolutely fine on standard suspension.
You could get a nice stance with them too, you planning on purchasing coilovers?
165s will give you a little bit more room..... and stretch 8)
Posted: Sat Apr 26, 2008 8:03 am
by vw-po-low
Thanks man, look's like they'll be going on today! :D I was just going to use lowring springs, as i dont have the money for coilovers, ha. Found a set that drop 50mm all the way around, not sure how low i can go with these wheels.
Posted: Sat Apr 26, 2008 10:58 am
by NOZ
Lowerage would also depend on the ET, the lower the ET the wider the rims stick out of the car. However, in this case your not lowering too much so its easily sorted using a different tyre profile.
Posted: Sat Apr 26, 2008 1:12 pm
by Tim_GTi
They should be fine with 50mm springs.
ATS Cups have an et 28
Posted: Sat Apr 26, 2008 7:24 pm
by vw-po-low
Well they're on! Think it will be lowerd in about 1 - 2 weeks.
Posted: Sun Apr 27, 2008 12:07 am
by Tim_GTi
Cool cool, definitely needs slamming!
