How common is this fault?
Posted: Fri May 02, 2008 9:36 am
My girlfriends 1.4 16V has been a good little car until the other day when depressing the clutch and bang! The pedal went to the floor. Pedal didn't come back up.
Upon looking, the metal bracket that holds the clutch cable in place which should be an attached part of the pedal box has litteraly snapped off. Oh joy!
A friend said this actually happend to his 2001/Y Golf GTi (Ours is also 2001/Y) and a garage I spoke to reckons they have seen it before on Polo's. So has anyone else had this problem? If so I wonder if it's a known fault maybe I could approach VW with some strength in the case?
It'll probably cost us around £2-300 to fix by the sounds of it so any help/advise would be greatly appreciated.
And then we'll sell it! (it's flippin clean by the way!!!)
