fog light guide?
Posted: Tue May 06, 2008 5:57 pm
by sniblett15
hello
does any body have the pics to go along with the guide for fitting oem fogs onto 6n2 by any chance?, (was written by polo2k years ago).
just dont want to go yanking wires and stuff
Posted: Tue May 06, 2008 7:51 pm
by alexperkins
Its easy peasy to do
To change the switch - push the headlight switch in and turn to sidelights, then it will pull out with gentle force
To fit the lights, the wiring is already in there. You just need to unclip it from its blanks mounted on the chassis - you can see them if you have a look under the bumper or through the fog opening.
Then fit the three split plastic inserts into the bumper, attach the cable to the back of each fog light, then screw in place
All that is left is to test them, and adjust to ensure the beam is the right height.
Hope this helps - any more help just ask
Posted: Tue May 06, 2008 10:41 pm
by sniblett15
alexperkins wrote:Its easy peasy to do
thank you mate got the switch done but got a bit dark to do the rest so will have to do 2mo!!!
cant wait until its done tho, hopefully no prob will come up
