Went & looked at a ’96 mk4 Polo, which is really tidy & extremely clean. Documented low mileage, main dealer history until recently, local reg etc.
One slight downer is it only has one key/remote, how easy is it to get a replacement, main stealer job or can I get a blank, have it cut & then program it at the stealers or via VAG-COM myself ?
Key/Remotes
A new blank key and cut would cost you around £5-10, but the key would not contain an immobilizer chip.
So best thing to do is find a blank key with an immobilizer chip, good places for this would be ebay. Once you got a blank key with immobilizer chip you will need to get it cut, this will cost you no more than £5. The next bit is expensive, the programming of the immobilizer chip would cost somewhere between £52-82 (the price is dependent on whether you know the 5 digit code to the car) if the security code is not known then go dealership. Expect to pay around £82, also you will require all documents to the car and personal details as well as the car needs to be bought down when getting the key programmed.
solidsponge
