upgraded alernator
Posted: Tue May 27, 2008 11:04 pm
by rick
need an upgraded alernator running at about 200 amp. where can i get 1 from??
Posted: Wed May 28, 2008 12:50 am
by alexperkins
Why you looking to uprate the alternator buddy? Thats alot of amps your talking!
Posted: Wed May 28, 2008 11:27 am
by rick
i'm running a 4000w sound system
Posted: Fri May 30, 2008 11:45 am
by ozzi25
How much Watts RMS are you running?
Posted: Fri May 30, 2008 1:13 pm
by rick
about 2500 rms
Posted: Fri May 30, 2008 1:55 pm
by ozzi25
If your Vsupply is 14.4v you would need a alternator running 187 amps so a 200 amp alternator would be suitable depending on your Voltage loss, but this should be very small (~0.4) if your using 1 or 0 guage wiring.
Posted: Fri May 30, 2008 1:58 pm
by rick
well wen i play some songs the voltage drops to 11.1 V using 0 guage
Posted: Fri May 30, 2008 2:06 pm
by ozzi25
Thats a big drop of voltage mate, I will advise you get a new alternator or a separate battery together with a split charger. Your voltage drop could increase your alternator current to 220 amps+. Which power cap are you using?
Posted: Fri May 30, 2008 3:58 pm
by rick
i've got a 2.4 farad just to stabalise the lights..
