Weird smell and misting windscreen
Posted: Wed Jun 11, 2008 12:31 pm
by Dan 6N
Hi all,
I was driving along the other day and it was late at night and dark and it started raining. My windscreen started misting up so I thought ok, I'll get the heat on the windscreen, so I turned on the heater and the fan thing to try and clear the screen but rather than clearing it, it just made it worse
Also, the heater chucks out a musty sort of smell when you turn it on,
Any ideas whats up?
Posted: Thu Jun 12, 2008 9:41 pm
by jonnopolo
Hi Dan, could be your pollen filter needs changing. Easy job to do.
Posted: Thu Jun 12, 2008 10:05 pm
by Polo96CL
Dan, take a look at this thread as I had a very similar problem. You posted in it a while back, refresh and see wether it's any use...
http://www.tigerstyle.co.uk/poloforum/v ... c&start=15
Daz
Posted: Thu Jun 12, 2008 10:12 pm
by jonnopolo
I realise it's off topic, but I have to say Darren that car of yours looks mint !
Posted: Fri Jun 13, 2008 1:16 pm
by Dan 6N
Thanks guys, I think its more of a problem with water being in the heater matrix rather than inside the actual car, I changed the pollen filter a while back and there is no water inside the actual car now...
And indeed, your car looks mint Darren!
Posted: Fri Jun 13, 2008 5:58 pm
by jonnopolo
A leaking matrix you think?
Posted: Tue Jun 17, 2008 11:20 pm
by Mike
Sounds like it, check the header tank to see if you lost any coolent, also check the carpets for dampness. also behind the dash for any signs of staining or water.
Posted: Wed Jun 18, 2008 4:52 pm
by iggy350
Defo sounds like your heater matrix. I had this prob last summer. I went to my local go to guy. he confirmed it. there was also a little water leakage. So he said just get some Radweld and put it straight in the water tank. I did that and it totall fixed the problem and its been about a year now with no probs at all.
Hope it helps you. Cos if it is that you need a new matrix, I pretty much requires the dash out, altho i hear you can just take the front area of your dash off and get to it as well
Posted: Mon Aug 18, 2008 1:23 pm
by lee s3 plo
have u had a screen fitted lately
Posted: Mon Aug 18, 2008 8:19 pm
by Dan 6N
Thanks everyone for your replies
lee s3 plo wrote:have u had a screen fitted lately
No, I haven't..
