Sound like a loose bolts when releasing clutch
Posted: Sat Jun 28, 2008 1:30 pm
by pepitopinoy
hello everyone!
I noticed yesterday that when i change gear(while moving only) and release the clutch pedal, there is a noise like a vibrating loose bolts. And it disappear when the clutch is fully released and fully pressed. i noticed that when the gear engages, and everytime i stepped on the gas pedal, the sound appears and disapper afterwards.
any advice about this is deeply appreciated.
by the way, the car is an 02 polo tdi 4 door
Posted: Thu Jul 03, 2008 5:43 pm
by poloecosse
sounds like the clutch release bearing is causing the noise
Posted: Thu Jul 03, 2008 11:34 pm
by TDI_Burd
mine has been making this noise since ive had it and i spoke to a pal who works in Vw n its supposidly a common fault but then again u could change the clutch and the clutch release bearing and it could do the noise anyway!
does this sound about right guys?
Posted: Fri Jul 04, 2008 8:42 am
by pepitopinoy
Thanks for the advice........
I'll advice my mechanic about that.
BTW, how much it cost to replace a clutch release bearing and a new clutch? Any idea?
Thank you again
